Hey guys,
So I'm trying to interface with a MAX11632 ADC using an Arduino UNO board without using any SPI through the MISO, MOSI, CS, and SCK pins. The data sheet for this specific ADC can be found here: MAX11632 pdf, MAX11632 Description, MAX11632 Datasheet, MAX11632 view ::: ALLDATASHEET :::.
This is the code I've written so far:
#include <SPI.h>
//Pin definitions
const int CS0 = 4;
const int CS1 = 5;
const int CS2 = 6;
const int DECODER_EN = 7;
const int MOSIPIN = 11;
const int MISOPIN = 12;
const int SCKPIN = 13;
//packet structure bytes
byte START_BYTE = '*';
byte END_BYTE = '#';
byte DELIMITER = ',';
//enumeration of channels for loops
//enum channels { CH0, CH1, CH2, CH3, CH4, CH5, CH6,
//CH7, CH8, CH9, CH10, CH11, CH12, CH13, CH14, CH15 };
//array of conversion registries
byte channels[] = {B10000100, B10001100, B10010100,
B10011100, B10100100, B10101100, B10110100, B10111100, B11000100,
B11001100, B11010100, B11011100, B11100100, B11101100, B11110100,
B11111100};
//Other two setup registries
byte setupReg = B01111000;
byte averageReg = B00111100;
byte reg1 = B10000100;
byte reg2 = B10001100;
byte convReg = reg1;
pinMode(CS0,OUTPUT);
pinMode(CS1,OUTPUT);
pinMode(CS2,OUTPUT);
pinMode(DECODER_EN,OUTPUT);
pinMode(MISOPIN,INPUT);
pinMode(SCKPIN,OUTPUT);
pinMode(MOSIPIN,OUTPUT);
//Set up ADC we wish to comm with
//But don't start comm
//This circuit has a chip select decoder to determine which of the 5 adcs to look at
digitalWrite(DECODER_EN,LOW);
digitalWrite(CS1,HIGH);
digitalWrite(CS0,HIGH);
digitalWrite(CS2,HIGH);
//Set clock low to prepare for data write
digitalWrite(SCKPIN,LOW);
delay(2500);
byte result;
// Serial.println(START_BYTE);
// for(int i = 0; i < 2; i++){
// byte convReg;
// if (i == 0){
// convReg = reg1;
// else{
// convReg = reg2;
//First we give the ADC register settings
//takes input on rising clock edge
digitalWrite(DECODER_EN,HIGH);
digitalWrite(SCKPIN,HIGH);
analogWrite(MOSIPIN,setupReg);
analogWrite(MOSIPIN,averageReg);
analogWrite(MOSIPIN,convReg);
//We then let the ADC run conversion
delay(10);
//sends data to DOUT on falling clock edge
result = analogRead(MISOPIN);
//start comm with ADC again
//read result from dataout
//once we have data cut off comm
//print out result
Serial.println(result,DEC);
//Serial.println(DELIMITER);
//Serial.println(END_BYTE);
I'm pretty sure the ADC is not working the way it should, as I'm getting pretty much the exact same numbers no matter whether I'm reading from a channel connected to a Hall-effect sensor or a channel connected to a thermistor.
Any sort of nudge in the right direction would be much appreciated.
Thanks in advance!
