Hi, folks. Does anyone know why I can't successfully download a text file to my Yun? While debugging, it seems the cd command is working fine (I can ls the directory) but the downloaded file never shows up on the SD.
I based my code on the web camera from Neuroballs: http://neuroballs.com/2014/01/how-to-build-a-arduino-yun-powered-cat-camera/ (only downloading instead of uploading)
I've tried every variation of curl in the manual. I've even tried wget. I can run that curl command from the shell prompt. I even tried runShellCommandAsynchronously. After three days, and a ton of searching, I'm stumped. Any help would be appreciated.
// download remote file card to SD
#include <Process.h>
// Initialize the Bridge and the Serial
Serial.begin(9600);//
while(!Serial); // wait for Serial port to connect.//
Serial.println("Save text file\n");//
Bridge.begin();
void loop(){
Serial.print("reading file...");
Process p;
p.runShellCommand("cd /mnt/sda1/");
p.runShellCommand("curl -O http://api.mywebserver.com/1/textfile.txt");
Serial.println("Done. Do other things now.");
delay(30000);
..and yes, I did upgrade my Yun
edit: I saw this thread, but it doesn't seem to be related to my issue: [SOLVED] Arduino Yun: uploading www folder to SD card doesnt work - Arduino Yún - Arduino Forum
-Vince
Vincefarq:
It does not work like this. Once you've CDed into a folder, next command will NOT start from that folder: every single command runs independently of the results of the previous ones.
Use
p.runShellCommand("curl -O http://api.mywebserver.com/1/textfile.txt > /mnt/sda1/textfile.txt");
Ah! That is great to know. I assumed the commands were being run in sequence as if I were issuing them from the shell.
Thank you! The file is showing up now!
-Vince
Please can you change the topic to [SOLVED] ?
So the (mytextfile) file is showing up, but it's empty
Any ideas why? everything works fine from the command line.
Process p;
//p.runShellCommand("cd /mnt/sda1/");
p.runShellCommand("curl 'http://api.mysite.com/1/index.php?cliid=07b9&imgwd=8&imght=8&numimg=8&verbose=no&formSubmit=Submit' > /mnt/sda1/temp.html");
p.runShellCommand("curl -O 'http://api.mysite.com/1/mytextfile.txt' > /mnt/sda1/mytextfile.txt");
-Vince
Google for "curl man": I think -O is interfering with output redirection
Footnote:
This eventually worked after days of debugging:
p.runShellCommand("curl 'http://api.mywebserver.com/phpfile.php?name1=value1&name2=value2&name3=value3' > /mnt/sda1/textfile.txt");
It seems there were two things wrong:
- firstly, -O never worked for me outside of the command line, and I've run out of curiosity to find out why.
- secondly, I was also running a bunch of libraries (and had a few arrays) which chewed away at my memory and caused some unpredictable behavior (like my Yun resetting intermittently)
Just leaving a note for future sufferers. Good luck!
-Vince
