SOLVEDError: SoftwareSerial.cpp:41:27: fatal error: avr/interrupt.h in IDE 1.6.7
I am having some very strange issues since upgrading to IDE 1.6.7 (from 1.0.6, so I don’t know when the problems would have started). The person I am working with is having the same problem, so I don’t think its the installation.
First, the IDE doesn’t recognize ‘byte’, so I have to define it:
#define byte uint8_t
Then, it doesn’t include the SoftwareSerial library and the Library Manager doesn’t have it either. I downloaded it from GitHub.
When I installed it, I get the following error:
/Arduino/libraries/SoftwareSerial/SoftwareSerial.cpp:41:27: fatal error: avr/interrupt.h: No such file or directory
 #include <avr/interrupt.h>
However, when I look, there are a few avr folders with interrupt.h in it.
I’m lost as to how to go further. What should I do here?
This is a board problem. I am using the new Artik and the library is not yet playing well with it.
Hi; I noticed that this is marked 'SOLVED' however I cannot see a solution? I am also having the same issue when referencing the avr/interrupt.h in an Arduino library. Any pointers are appreciated! Thank you.
