Solving real time Ordinary Differential Equations with arduino Uno
Hello,
what is the best way to solve a system of differential equations using arduino?
An example would be
  //c_i = constant
   a_dotdot = c_1*b + c_2*a + c_3;
   b_dot = c_4*a + c_5*b + c_5;
Thank you.
think one c_5 must be c_6
AKJ:
Hello,
An example would be
  //c_i = constant
a_dotdot = c_1b + c_2a + c_3;
  b_dot = c_4a + c_5b + c_5;
Thank you.
You'd want to integrate both equations, then integrate the first again. Integrate wrt time? and are the parameters from a sensor? Then accumulate the signal over a period of time, and there is the result of your integral. Once you have solved the integrated, linear equations for a and b, plug and chug.
ChrisTenone
Thanks.
The "best way to solve ... using Arduino" would be one of the many ways that one would ordinarily use to solve such a system, but can be squeezed into the Arduino's tiny memory and execute in a reasonable amount of time, given the slow clock.
First, enumerate the ways, then decide what might work. "real time" is of course not an option.
