I am running Arduino 1.6.3 and it didn’t have the DUE available under Tools Boards. Fixed this by loading it under Board Manager.
When I now compile and try to load a program it compiles fine but when loading it says No device found on Com 12.
Now Com 12 according to system manager is fine - it is where the PC allocated the DUE device and says under Ports - Arduino Due Programming Port (COM 12).
So why the error?
Also which programmer should I use on the list? I have AVR ISP selected.
Yes I installed the core separately as you said. If it's a windows problem then I'm stuffed! Yes I'm using the programming port. I wonder if it's permissions?
Ok I found this on a FORUM, not good but it works. There is a bug in the firmware somewhere
SOLVED
You need to do three very simple things after connecting the Programming port with the computer/laptop :
Press the erase button for about 3 seconds.
2.Press the reset button.
Upload the code.
You need to do this every time you want to upload a sketch. Everything else will hopefully work fine after that.
P.s : I think the problem is the board is not erasing the data pre-written or something.
And it is all done. Tried , tested , worked. Cheers !
I am using the native USB which is faster anyway. I found when you reset that the COM port changes - look on Device Manager! It only changes once - for me from COM 16 to COM 15 and then it started working without the reset thing. So I am ok so far.
