So I have a loop that does digital out pwm from 1 - 255 then 255 back to 1.
Well I noticed some digital out pins work and some don't.. what I mean is some out's will fade properly but others just go ON or OFF.
So the LED will turn on and then turn OFF instead of fading- is this a known issue or am I doing something wrong?
Thanks in advanced!
bens
#2
The mega168 only has six hardware PWM outputs. If you want to PWM a non-hardware PWM pin, you need to do it in software.
Okay that makes sense, could you direct me to which pins on the arduino are the pwm pins?
system
#4
... the pins that have "PWM" sikscreened on the board are the ones that do PWM.
