SOME DOUBTS IN TinyGPSPlus.h EXAMPLE CODE
#include <TinyGPSPlus.h>
   This sample sketch should be the first you try out when you are testing a TinyGPSPlus
   (TinyGPSPlus) installation.  In normal use, you feed TinyGPSPlus objects characters from
   a serial NMEA GPS device, but this example uses static strings for simplicity.
// A sample NMEA stream.
const char *gpsStream =
  "$GPRMC,045103.000,A,3014.1984,N,09749.2872,W,0.67,161.46,030913,,,A*7C\r\n"
  "$GPGGA,045104.000,3014.1985,N,09749.2873,W,1,09,1.2,211.6,M,-22.5,M,,0000*62\r\n"
  "$GPRMC,045200.000,A,3014.3820,N,09748.9514,W,36.88,65.02,030913,,,A*77\r\n"
  "$GPGGA,045201.000,3014.3864,N,09748.9411,W,1,10,1.2,200.8,M,-22.5,M,,0000*6C\r\n"
  "$GPRMC,045251.000,A,3014.4275,N,09749.0626,W,0.51,217.94,030913,,,A*7D\r\n"
  "$GPGGA,045252.000,3014.4273,N,09749.0628,W,1,09,1.3,206.9,M,-22.5,M,,0000*6F\r\n";
// The TinyGPSPlus object
TinyGPSPlus gps;
  Serial.println(F("BasicExample.ino"));
  Serial.println(F("Basic demonstration of TinyGPSPlus (no device needed)"));
  Serial.print(F("Testing TinyGPSPlus library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  while (*gpsStream)
    if (gps.encode(*gpsStream++))
      displayInfo();
  Serial.println(F("Done."));
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
MY DOUBT:- I AM ALL CLEAR WITH THE ABOVE CODE EXCEPT THE METHOD- gps.encode(), WELL I HAVE GONE THROUGH SRC FILES BUT STILL NOT CLEAR ABOUT WHAT THAT METHOD DOES AND RETURNS. PLS HELP ME OUT! - I HAVE ATTACHED THE TINYGPS LIBRARY FILE BELOW.
TinyGPSPlus.h (1.1 KB)
gps.encode() processes the characters, from a GPS, works out if the sentence is valid NMEA, and returns true if valid and false if not.
The use of the function is described in the documentation;
http://arduiniana.org/libraries/tinygpsplus/
