Hello everyone!! I would like to know what is my error in my code… So first, I should tell what I’m doing/ what I have… I have a Gizduino Plus 644 ( a copy of Arduino with ATmega 644 here in the Philippines…), a IR Proximity Sensor (Digital - 0 or 1), LED and some resistor.
In this code, everything is working perfectly…
If the proximity sense something, the LED will turn on.
int PROX = 12;
int SENSOR = 2;
int SENSOR_LED = 7;
pinMode(PROX, OUTPUT);
pinMode(SENSOR, INPUT_PULLUP);
pinMode(SENSOR_LED, OUTPUT);
digitalWrite(PROX, HIGH);
digitalWrite(SENSOR_LED, LOW);
int VAL = digitalRead(SENSOR);
if (VAL > 0)
digitalWrite(SENSOR_LED, HIGH);
But when I try it to this code… There’s some error… If I run the program (upload it), and type “QRIN” the LED is already ON even if the Proximity doesn’t sense anything… And if I type “QROUT”, the LED is still on… In which it should not.
int LOCK = 13;
int PROX = 12;
int SENSOR = 2;
int PROX_SENSOR_LED = 7;
pinMode(LOCK, OUTPUT);
pinMode(PROX_SENSOR_LED, OUTPUT);
char data = Serial.read();
switch (data)
case 'QRIN':
digitalWrite(LOCK, HIGH);
digitalWrite(PROX_SENSOR_LED, HIGH);
SENSOR_LED();
case 'QROUT':
digitalWrite(PROX, LOW);
LED_OFF();
delay(10000);
digitalWrite(LOCK, LOW);
void SENSOR_LED()
if (VAL > 0)
void LED_OFF()
if (VAL > 0)
digitalWrite(PROX_SENSOR_LED, LOW);
I’m doing this because I need this for a project… I have a c# program that if the QR that my Webcam reads is correct, the “QRIN” will execute and if the other Webcam reads the QR is correct, it will execute “QROUT”… ← this is already working… The only problem is my code in Arduino IDE…
I’m really sorry for the long post… Please bear with me… I’m really new to Arduino…
