Some Error in Program, Need Solution
Error massage-
C:\hc_05_relay_buzzer_by_uno\hc_05_relay_buzzer_by_uno.ino: In function 'void setup()':
hc_05_relay_buzzer_by_uno:84:3: error: a function-definition is not allowed here before '{' token
hc_05_relay_buzzer_by_uno:100:3: error: expected '}' at end of input
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
exit status 1
Code:
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
int relay = 6;
int buzzer = 7;
char c = ' ';
// BTconnected will = false when not connected and true when connected
boolean BTconnected = false;
// connect the STATE pin to Arduino pin D4
const byte BTpin = 4;
  // set the BTpin for input
  pinMode(BTpin, INPUT);
  pinMode(relay, OUTPUT);
  pinMode(buzzer, OUTPUT);
  // start serial communication with the serial monitor on the host computer
  Serial.println("Arduino is ready");
  Serial.println("Connect the HC-05 to an Android device to continue");
  // wait until the HC-05 has made a connection
  while (!BTconnected)
    if ( digitalRead(BTpin) == HIGH)  {
      BTconnected = true;
      digitalWrite(relay, HIGH); // This will Turn the Relay On
      digitalWrite(buzzer, HIGH); // This will Turn the Buzzer On
      delay(3000); // Wait for 3 seconds
      Serial.println("HC-05 is now connected");
      Serial.println("");
      // Start serial communication with the bluetooth module
      // HC-05 default serial speed for communication mode is 9600 but can be different
      BTserial.begin(9600);
    { digitalWrite(relay, LOW); // This will Turn the Relay Off
      delay(1000); // Wait for 1 seconds
      digitalWrite(buzzer, LOW); // This will Turn the Buzzer Off
      Serial.println("HC-05 is now disconnected");
      Serial.println("");
      // Start serial communication with the Bluetooth module
    // Keep reading from the HC-05 and send to Arduino Serial Monitor
    if (BTserial.available())
      c = BTserial.read();
      Serial.write(c);
    // Keep reading from Arduino Serial Monitor input field and send to HC-05
    if (Serial.available())
      c =  Serial.read();
      BTserial.write(c);
Can you please edit your post to put the code inside code tags.
You are also missing a } at the end of setup! Using CTRL + T will auto format the code, and you will see the mismatch.
Your setup function is missing a final closing brace.
For the compile error, you're missing a brace at the end of setup():
      Serial.println("");
}// <-- missing this
missdrew:
Thanks for your reply,I have tryed ctrl +T /auto format but Don't get any solution.
But you have been given the solution, THREE times.
