Some help, please - unexpected behavior when interfacing load cell and keypad
Oay, this is going to be a bit of a novel, but please bear with me. I've been working on this for a while, and have tried a lot to get it working.
I've been in the process of building a powder trickler system for the past 3 months based around a Mega 2560 clone. The plan is to have the motor driver, load cell, keypad and LCD screen all controlled by the Arduino in a way that allows for standalone use.
My project consists of:
  • Storm Interface 720BLK 16 key matrix keypad
  • Sparkfun HX711 breakout
  • Sparkfun Serial-enabled 16x2 LCD screen
  • NEMA17 stepper motor
  • Big Easy Driver
  • Generic 100g load cell (I also have 50g and 500g cells on hand)
The hardware is all assembled (at least as far as the first prototype is concerned), and I have been able to get each of the individual components working on their own (though I haven't written the motor portion yet, I've been able to use sample code), and it's a pretty trivial matter to get the LCD working with the right libs (I even got bored and wrote out code to vary the backlight brightness). The trouble comes in when I try to add the scale functionality in on top of the keypad code.
I didn't write the keypad code; I actually pulled it from an older post on this site, where someone needed to input multi-digit sequences (I think they were building a lock or something). However, it was pretty easy to adapt it to my needs (or so I thought). The way it's written, the keypad keeps waiting for input until the # key is pressed, then it returns the integer value of whatever key combination the user presses - pretty straightforward.
Except when I add the scale code, the load cell doesn't update unless I press #, in which case it updates once, until I press it again. That's not practical, and it has a nasty habit of zeroing out the variable in the loop() function that's set to catch the readings. If I remove the call to GetNumber(), the load cell fires right up, and behaves properly.
I thought I might be able to use interrupts, so in looking over those in hopes of finding some sample code around which I could write a replacement for the GetNumber() function, I came across this blog post detailing a pseudo-interrupt event built into the keypad library. I gave it a go, and my limited test seemed to work - the load cell measured unimpeded, and I was able to put some digits up on the LCD screen (and moved my backlight code over as part of my test, which also worked). However, I don't think I'm remotely close to where the code needs to be to do what I want. I tried expanding it to look more like GetNumber(), and I even tried using the event to call GetNumber().
Anyway, this is the part where I ask for guidance. Please, any ideas you might have, I'd be grateful. I'm so close to getting it working I can taste it. And that is a frustrating feeling.
Okay, so it seems my code is too long to add in one post.
Here’s my code as it stands right now (1 of 2):
#include <kissStepper.h>
#include <HX711.h>
#include <SerLCD.h>
#include <SoftwareSerial.h>
#include <Keypad.h>
#define RX 2
#define LOAD_CELL_DAT 14
#define LOAD_CELL_CLK 15
#define EN 28
#define MS1 27
#define MS2 29
#define MS3 30
#define RST 26
#define STP 3
#define DIR 4
const uint16_t motorFullStepsPerRev=200;
kissStepper motor(
  kissPinAssignments(DIR,STP,EN,MS1,MS2,MS3),
  kissMicrostepConfig(MICROSTEP_8)
HX711 scale(LOAD_CELL_DAT,LOAD_CELL_CLK);
float calibration_factor=-2600;
float reading;
float v1 = 0;
//int v2 = 0;
//int v3 = 0;
float target=0;
int i=0,num=0;
const long interval=1000;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] =
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {5,6, 12, 11}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {7, 8,9,10}; //connect to the column pinouts of the keypad
Keypad key = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS );
SoftwareSerial lcdserial(0,RX);
SerLCD lcd(lcdserial);
int getaverageweight(int x)
  float weight=0,average=0,sum=0;
  for(i;i<=x;i++)
    weight=scale.get_units();
    sum=sum+weight;
  average=sum/x;
  return average;
void currentcharge()
  lcd.setPosition(2,0);
  lcd.print("Current:");
  lcd.setPosition(2,8);
  // 0.
  //average=getaverageweight(10);
  lcd.print(reading,1);
  //lcd.print(average);
void targetcharge()
  lcd.setPosition(1,0);
  lcd.print("Target:");
  lcd.setPosition(1,7);    //change cursor position on LCD to after
  Serial.print(target);    //Print variable "target" to the serial monitor for troubleshooting/verification purposes
  lcd.print(target,1);     //PRint target
  lcdserial.begin(9600);
  motor.begin(MICROSTEP_8,200);
  lcd.begin();
  lcd.displayOn();
  scale.set_scale(calibration_factor);
  scale.tare();
  lcd.setBacklight(157);
  lcd.print("LCD initialized");
  lcd.clear();
  key.addEventListener(keypadEvent);
   reading=scale.get_units();
   //v1 = GetNumber();        //Get raw data from keypad\
   //v1=key.getKeys;
   target=v1*0.1;           //multiply by 0.1 to get a number with tenths
   //target=num*0.1;
   //target=GetNumber();
   char state=key.getKeys();
   targetcharge();
   currentcharge();
   //if(currentweight<=(target-2)
(2 of 2)
int GetNumber()
   int num=0,num1=0;
   char customKey = key.getKey();
   targetcharge();
   currentcharge();
   //if(customKey)
   while(customKey != '#')
      //currentcharge();
      switch (customKey)
         //case NO_KEY:
            default:
            //currentcharge();
         case '0': case '1': case '2': case '3': case '4':
         case '5': case '6': case '7': case '8': case '9':
            num = num * 10 + (customKey - '0');
            //num1=num*0.1;
            //lcd.print(num1);
         case '*':
            num = 0;
            lcd.clear();
            targetcharge();
            currentcharge();
         case 'A':
            Serial.println("YES");
            lcd.print("YES");
         case 'B':
          scale.tare();
         case 'C':
          lcd.clear();
          currentcharge();
          targetcharge();
         case 'D':
              if(i==0)
                  i=i+1;
                  lcd.setBacklight(130);
                  lcd.clear();
                  lcd.print("Backlight off");
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
                  //if(currentMillis-previousMillis>interval)
                  //Serial.println(i);
              else if(i==1)
                  lcd.setBacklight(140);
                  i=i+1;
                  lcd.clear();
                  lcd.print("Backlight Low");
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
            else if(i==2)
                  lcd.setBacklight(150);
                  i=i+1;
                  lcd.clear();
                  lcd.print("Backlight Medium");
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
                  //delay(interval);
             else if(i==3)
                  i=i+1;
                  lcd.clear();
                  lcd.print("Backlight Max");
                  //lcd.print("Brightness 3");
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
                  i=0;
                else break;
                /*if('C'&&'1')
                    if(bpresses==0)
                    lcd.displayOff();
                    bpresses=bpresses+1;
                  else if(bpresses==1)
                      lcd.clear();
                      lcd.displayOn();
                      lcd.print("LCD On");
                      delay(interval);
                      bpresses=0;
     //currentcharge();
   return num;
void keypadEvent(KeypadEvent keystate)
  //int num;
  char button=key.getKeys();
  switch(key.getState())
    default:
    case PRESSED:
    v1=GetNumber();
    /*switch(keystate)
      default:
      //lcd.print("YES");
      num=num*10+(button-'0');
      //lcd.setPosition(1,7);
      //lcd.print(num);
      case 'B':
        if(i==0)
                  i=i+1;
                  lcd.clear();
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
              else if(i==1)
                  i=i+1;
                  lcd.clear();
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
            else if(i==2)
                  i=i+1;
                  lcd.clear();
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
                  //delay(interval);
             else if(i==3)
                  i=i+1;
                  lcd.clear();
                  delay(interval);
                  lcd.clear();
                  targetcharge();
                  currentcharge();
                  i=0;
                else break;
  //return num;
int bpresses=0;
/*void getcurrentweight()
  if(
