Some help with Pull-Up/Down on ESP01 ?
Mopheus:
Hi everyone, I have a simple question but after some research online I can't still figure out the solution. Sorry for my bad english. It's quite simple, I'm using this very easy circuit to control an IR led, but when I connect it to GPIO0 or GPIO2 on my ESP, it doesn't work. While it works on GPIO3 (RX)... so, I think it's because for some reason, when connected to GPIO0 is pulling up (or down) the pin and going into FLASH mode. Is it possible ?
Can someone help me understand how to change this circuit to work with GPIO0 (is the one I need to use actually).
Thanks.
Several things:
  • How are you determining that the IR LEDs are not working? You do realize that IR LEDs are not visible, right [unless you're a snake, or a very unusual human]? Is it that you have an IR receiver, and it isn't registering? Also, a quick way to verify that the IR LEDs are lighting up [or not] is to use a Digital Camera [can be on a Cell Phone]. Most digital cameras will show IR as a "color" [usually a pinkish white]. First, power up an IR LED using a DC voltage and a resistor [run it at 20mA, unless you know for sure it is rated to run at a higher continuous current]. Then, using the camera, peer down at it from the top. If you see a glow, then you have verified that your camera can, indeed, "see" IR. Then, do the same with the IR LEDs you are driving with the 2N2222.
  • You show 50mA as the current at the collector. Using an LED forward voltage of 1.1V, I get more like 79mA:
[5V - 2(1.1V) - 0.1V]/34Ω = 79.4mA where: 1.1V is the IF of each LED and 0.1V is the VCE(sat) of the transistor.
BUT, that's assuming a VCE(sat) of 0.1V. Even if the VCE(sat) is more like 0.3V, and each LED VF is more like 1.3V, I still get around 62mA:
[5V - 2(1.3V) - 0.3V]/34Ω = 61.8mA
So, are you over driving those LEDs. And could that have fried them?
  • Are the LEDs being held on for too long? Typically, such high currents are meant to only be applied for short periods, with a small duty cycle. Have you consulted a datasheet, and are you driving then correctly? This could be another reason the LEDs could have fried.
  • If you have a scope, take a look at the is happening across the Collector-Emitter junction. Do you see it toggling? If not, do you see a signal at the Base of the transistor? If not at C-E, then suspect the transistor. If not at the base, consider an open circuit somewhere, or even a short! Check to see if you see a signal at the GPIO output. If that's missing, it might be shorted, or the pin might be bad, or the sketch might not be written correctly.
