Some issue with Adruino Mini Pro and a SIM900 module
Dear All,
Actually I am working with a
  • Arduino Mini pro
  • A GSM module SIM900
  • A power adaptator to 4V to power the GSM module
See picture of my project
And here is the pin definition of my SIM900 GSM module
and I am using that library
http://code.google.com/p/gsm-shield-arduino/
I am a bit confused because it does not work and I always have that message
GSM Shield testing.
Trying to force the baud-rate to 9600
ERROR: SIM900 doesn't answer. Check power and serial pins in GSM.cpp
status=IDLE
Second suprising think; I never can call the SIM GSM module. It like if it is not powered or switched off. However, there is green led flashin
g
I have no experience with the SIM900 module that you can see in the first module and may be I have not wired it correctely.
Someone has an experience with that componment?
Could you check my wire connection and let me know your advises?
Many thank for your great help. It will really help me
Cheers
what is the baud rate that the gsm is set to.
have your tried a pass through sketch
look at this
different setup but it might shed some light
But it seams to be at 9600.
but what do you means by
using a pass through sketch you can use Serial monitor to send commands to the gsm module and get feedback from the gsm module to see what settings it uses. But you get more info
if you can use Terminal services. The link i sent you has a pass through sketch to do this. Not sure how you arduino board will work with it, you might have to edit some pins ect.
You should have a manual for the Gsm with the relevant AT commands you issue to the gsm module to find the relevant info.
I believe my frist issue is the pin1 of the SIM900 module.
I should not put a 4V put a pulse of 2sec.
But event if I add this in my setup() loop
in order to have a pulse
  digitalWrite(9, HIGH);
  delay(2000);
  digitalWrite(9, LOW);
it does not work
Someone has an idea about my issue?
I think my major issue is how to poser the GSM shield.
There is a pin1 where I am supposed to send a pulse of 2sec.
I did this but it did not work
  delay(2000);
  Serial.println("GSM Shield testing.");
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
//if (inet.attachGPRS("internet.wind","", ""))
    if (inet.attachGPRS("internet","", ""))
      Serial.println("status=ATTACHED");
    else Serial.println("status=ERROR");
    gsm.SimpleWriteln("AT+CIFSR");
    delay(5000);
    gsm.WhileSimpleRead();
    numdata=inet.httpGET("aaaaaaa.dyndns.org", 80, "/", msg, 50);
    Serial.println("\nNumero d'octet recu:");
    Serial.println(numdata);
    Serial.println("\nData recived:");
    Serial.println(msg);
Thank for helping
How do I send this pulse if I don't have the shield, rather just the module?
