Malti:
so what should i do i want to make a pot meter controlled temp threshold changing circuit where relay would be used . i need two conditions as i uses if and while .pls help.
work is this to use........
Malti:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you please explain what you are trying to do with your code, what is it for?
You have a pot and a temperature sensor, please list all the cases you want to program into your code and the output responses.
This sounds like a switch.. case type solution.
Tom.... ![]()
while(condition) {
// At this point condition is true
while(condition) {
statement(s);
//If we are here, condition is false
statement(s);
so instead of using while loops i tried with if nested loops and the code was working fine ......
thanks to all those who replied and sorry for replying late.
