some problem with strcat
I have some problem with strcat, and I have no idea where the problem is.
I have following code for example.
some declaration
char dep1[6] = "00:00";
char dep2[6] = "00:00";
char divTime[3] = "00";
for my better understanding:
dep1 is an array = |0|0|:|0|0|\0|
dep2 is an array = |0|0|:|0|0|\0|
divTime is an array = |0|0|\0|
I hope so far thats correct.
the I have a function like this:
void getDepartures() {
  int i = 0;
  char jsonResponse[20];
  char *ptr;
  Process p;
  p.runShellCommand("/mnt/sda1/arduino/www/timetable/curl.php -t");
  while (p.running());
  while (p.available()) {
    char c = p.read();
    jsonResponse[i] = c;
    i++;
Serial.println(jsonResponse);
  ptr = strtok(jsonResponse, ","); // get first time
  strncpy(dep1, ptr, 6);
Serial.println(dep1);
  ptr = strtok(NULL, ",");         // get second time
  strncpy(dep2, ptr, 6);
Serial.println(dep2);
  ptr = strtok(NULL, ",");         // get div time
  strncpy(divTime, ptr, 3);
Serial.println(divTime);
  strcat(divTime, "'");
The response:
jsonResponse is an array = |1|2|:|3|8|,|1|3|:|4|5|,|2|6|\0| | | | | |
What I get on the serial monitor
22:38,23:08,26�
22:38
23:08
26�23:08
26�23:08'
What I not understand is this last part ..
26�23:08
26�23:08'
I would expect that the last two values are
26
26'
somewhere I was going a mistake ....
Thanks for helping.
Either set the jsonResponse array to all zeros, or this:
    char c = p.read();
    i++;
// add this
    jsonResponse[i] = 0;
divTime is a three element array.
How can it contain, as a C string, "26'"?
AWOL:
like this
| 2 | 6 | \0 |
or I'm wrong :roll_eyes:
2 6 '. \0
I make that four characters, including terminator.
strncpy() does not produce a nul terminated string if you get to the “n”.
So if you try to copy “12:38” using strncpy(X,Y,3) you get ‘1’ ‘2’ ‘:’ but no ‘\0’
SurferTim:
char c = p.read();
   i++;
// add this
ok, looks better. I got now
22:38,23:08,02
22:38
23:08
02'
so far so good ...
@KeithRB
so I have to add "\0" at the end of each
strncpy(dep1, ptr, 5);
dep1[6]= "\0";
strncpy(dep2, ptr, 5);
dep2[6]= "\0";
or just
// -> 22:38,23:08,02
// -> 22:38
strcpy(dep1, ptr);
dep1[6]= "\0";
// -> 23:08
strcpy(dep2, ptr);
dep2[6]= "\0";
AWOL:
2 6 '. \0
Right :smiley:
THANKS 4 help. It’s working proper now!!
