jediah
1
Hello, a newbie here
I am creating a blinking led-alarm for a intercom system. The output voltage of the intercom while pushing the call button is 6v.
What i exactly want to archieve:
If the 6v pulse is high for less than 2/3 seconds, the led(s) need to blink for +/-10 seconds.
If the 6v pulse is high for more than 3/4 seconds, the led(s) need to blink continuous until the button is released.
i already measured the value via Serial.write, the max value is 438.
The (horrible) code i already wrote.. but it doesnt work..
I got this error: call_read:17: error: expected unqualified-id before 'if'
What am i doing wrong?!
Intercom Led-blinker for Richard
Author: jediah
Date: February 24 2012
const int pulseSource = A0; // +V from 6v source is connected to analog pin A0
const int ledBlinker = 8; // Output to led(s)
pinMode(ledBlinker, OUTPUT);
if (analogRead(pulseSource) == LOW)
int val = analogRead(pulseSource); // realtime valure from powersource
time = millis();
delay(200); //debounce
if (val == > 420 && time - millis() >1000)
digitalWrite(ledBlinker, HIGH);
delay(100);
digitalWrite(ledBlinker, LOW);
delay(100);
else if (val == > 420 && time - millis() >2000)
delay(200);
delay(200);
(Excuse me for my bad english)
It is complaining about this "== >". I presume you intended this to mean "greater than or equal" in which case what you need is ">=".
Pete
cmiyc
3
How can you use "time" before you declare it?
bradb
4
And probably a stupid question, but you didn't directly connect 6v to A0 did you? (10 Ways to Destroy an Arduino — Rugged CircuitsRugged Industrial Arduino Microcontrollers)
If so, you really don't want to do that
Brad (KF7FER).
jediah
5
Good to mention, but i didnt do that
I thought -seen from another code- that it was declared by doing this: time = millis();
el_supremo:
Pete
Yes indeed, i wanted to get greater than or equal
system
6
That would assign the current millis() value to time, but you need to declare time first. Either as separate statement:
unsigned long time;
or including the assignment:
unsigned long time = millis();
The biggest problem you have though is a complete lack of a loop() function.
All of this:
if (val >= 420 && time - millis() >1000)
delay(100);
delay(100);
else if (val >= 420 && time - millis() >2000)
delay(200);
delay(200);
is currently outside of any function, which is not allowed. It should be inside the loop() function.
