Hey, I build an kinda LED cube on a breadboard (http://img651.imageshack.us/img651/1073/img0589f.jpg). all the cathodes on each level are connected ( pins 2-4 are level pins )
and each anode is connect to the same anode on a diffrent level ( pins 5-13 )
it work fine but there is some minor problem: The last led (number 9 on pin 13) is "HIGH" for just 1/9 of the time that the first led is HIGH (pin 5), therefore that led is much darker. I used this (Arduino Reference - Arduino Reference) method to decrease the time of turning all LEDs off. I manged to get it to be exectuted in 200Microseconds ( when time = 1 )
Am i doing it right, or there is a more efficient way to do this?
Look at the code over here:
boolean led[3][3][3]; // led cube
int l,x,y,i; // l-level
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
for(l=0;l<3;l++) for(y=0;y<3;y++) for(x=0;x<3;x++) { led[l][y][x] = LOW; } // set all to LOW
for(y=0;y<3;y++) for(x=0;x<3;x++) { led[0][y][x] = HIGH; } // set level 0 to HIGH
array_process(1);
void array_process(long time){
for(i=0;i<time;i++)
for(l=0;l<3;l++)
PORTD = B00011100; // Pins 2-4 => HIGH | Pins 5-7 LOW
PORTB = B00000000; // Pins 8-12 LOW
if( l == 0 )
digitalWrite(2,LOW); // set 1st level catoda to low
for(y=0;y<3;y++)
for(x=0;x<3;x++)
digitalWrite((5+x+y*3),led[l][y][x]); // pin 5 is the first led
if( l == 1 )
digitalWrite(3,LOW);
for(y=0;y<3;y++)
for(x=0;x<3;x++)
if( l == 2 )
digitalWrite(4,LOW);
for(y=0;y<3;y++)
for(x=0;x<3;x++)
