I bought this module for $2 on aliexpress and I know where to solder the components but I am not quiet sure about the orientation (+/- pole). Bigger image here
So I got 2 LEDs, 2 Capacitors, 3 resistors and one bigger capacitor. I know how to solder everything but here is what I dont understand:
I think one small smd capacitor is missing, right?
The two LEDs obviously goes to D1 and D2 but how am I supossed to know where the + and - pole on the board is? On the LED a small green dot marks the - pole. Same for the bigger capacitor. Where is +/- on the board?
you want only 3 capacitors. the C1 and C2 are connected to the same pin.you only need to connect 1 of this at same time.if you can tell the Vcc and the Gnd i can tell you which way the poles of the leds are.
There are 3 capacitors and 3 places for caps on the board, what's the issue? The large cap is a
tantalum cap, make sure when you orient it you look up the polarity marking for a tantalum cap,
not an aluminium electrolytic, they are different. Remember the ground-pour on the board usually makes it
easy to work out which is the +ve and -ve end of a component as ground is negative (in modern
logic circuits).
Oh yes, C1 was hiding from me(!). I suspect the module already has high-speed decoupling, but
it would be best to have the schematic to hand to figure out the implications.
MarkT:
I blame my bad eyesight, but I didn't see all four at first either.
Really, the instructions/schematic would be handy. I never buy anything without checking on that sort of thing beforehand, along with availability of libraries and further documentation where applicable.
