I'm pretty new to coding, and I'm in an engineering class where we've just started working with Arduino. The project I'm working on is basically a heat sensor that works as a 'Love-O-Meter.' It's pretty dumb and simple but I'll put the list of errors below.
14:15: error: stray '\342' in program
14:16: error: stray '\200' in program
14:17: error: stray '\234' in program
14:32: error: stray '\342' in program
14:33: error: stray '\200' in program
14:34: error: stray '\234' in program
18:15: error: stray '\342' in program
18:16: error: stray '\200' in program
18:17: error: stray '\234' in program
18:27: error: stray '\342' in program
18:28: error: stray '\200' in program
18:29: error: stray '\234' in program
In function 'void loop()':
14:18: error: 'Sensor' was not declared in this scope
14:18: note: suggested alternative: 'perror'
18:18: error: expected primary-expression before ',' token
18:20: error: 'Volts' was not declared in this scope
exit status 1
const int sensorPin = A0;
const float baselineTemp = 20.0;
void setup(){
Serial.begin(9600); // open a serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print(“Sensor Value: “);
Serial.print(sensorVal);
// convert the ADC reading to voltage
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print(“, Volts: “);
Serial.print(voltage);
Serial.print(", degrees C:");
// convert the voltage to temperature in degrees
float temperature = (Volts - 0.5) * 100;
Serial.println(temperature);
if (temperature < baselineTemp){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
}else if(temperature >= baselineTemp+2 && temperature < baselineTemp+4){
digitalWrite(2, HIGH);
}else if(temperature >= baselineTemp+4 && temperature < baselineTemp+6){
digitalWrite(3, HIGH);
}else if(temperature >= baselineTemp+6){
digitalWrite(4, HIGH);
delay(1);
[tt]
[/tt]
