Hi all.
the ESP32 testing works well when usb connected to pc and the Arduino IDE's Serial monitor is open, otherwise the button reaction quite slow, what can be?
there is no while (!Serial) ;
in sketch.
Thanks
Adam
That's interesting.
The problem is probably in the sketch that you have not posted or the details of the project that you have shared
We can only take your word for that.
the sketch do used: serialIn serial...
L 329: while(!Serial);
is commented out still got button lag...
Found there are many Serial in L240 - L251...
L240: serialIn serial(Serial); commented out got error: 'serial' was not declared in this scope
at L 268, how to fix it get ride of serial if it is the reason of button slow.
is here the serial mean open the ESP32's serial?
#include <Arduino.h>
#define PROG_VERSION "0.2" // Don't change this!
//#include <SPI.h>
#include <TFT_eSPI.h>
#include <Button2.h>
#include "bmp.h"
#ifndef TFT_DISPOFF
#define TFT_DISPOFF 0x28
#endif
#ifndef TFT_SLPIN
#define TFT_SLPIN 0x10
#endif
#define TFT_BL 4 // Display backlight control pin
#define LED_CTRL 0 // Pinnumber of external led to control. Set to 0 if there isn't a external led attached.
int ledBacklight = 80; // Initial TFT backlight intensity on a scale of 0 to 255. Initial value is 80.
#define BTN_UP 14 // Pinnumber for button for up/previous and select / enter actions (don't change this if you want to use the onboard buttons)
#define BTN_DWN 0 // Pinnumber for button for down/next and back / exit actions (don't change this if you want to use the onboard buttons)
#define BTN_Start 13
#include <menu.h>
#include <menuIO/serialIO.h>
#include <menuIO/TFT_eSPIOut.h>
// #include <menuIO/chainStream.h>
#include <menuIO/esp8266Out.h>//must include this even if not doing web output...
using namespace Menu;
TFT_eSPI gfx = TFT_eSPI(); // Define TFT_eSPI object with the size of the screen: 135 pixels width and 240 pixels height. We will rotate it later a quarter clockwise.
Button2 btnUp(BTN_UP); // Initialize the up button
Button2 btnDwn(BTN_DWN); // Initialize the down button
Button2 btnStart(BTN_Start);
result doAlert(eventMask e, prompt &item);
int test=55;
int menuBJ = 0;
int ledCtrl=LOW; // Initial value for external connected led
// Setting PWM properties, do not change this!
const int pwmFreq = 5000;
const int pwmResolution = 8;
const int pwmLedChannelTFT = 0;
result myLedOn() {
ledCtrl=HIGH;
return proceed;
result myLedOff() {
ledCtrl=LOW;
return proceed;
TOGGLE(ledCtrl,setLed,"Led: ",doNothing,noEvent,noStyle//,doExit,enterEvent,noStyle
,VALUE("On",HIGH,doNothing,noEvent)
,VALUE("Off",LOW,doNothing,noEvent)
int selTest=0;
SELECT(selTest,selMenu,"Select",doNothing,noEvent,noStyle
,VALUE("Zero",0,doNothing,noEvent)
,VALUE("One",1,doNothing,noEvent)
,VALUE("Two",2,doNothing,noEvent)
int chooseTest=-1;
CHOOSE(chooseTest,chooseMenu,"Choose",doNothing,noEvent,noStyle
,VALUE("First",1,doNothing,noEvent)
,VALUE("Second",2,doNothing,noEvent)
,VALUE("Third",3,doNothing,noEvent)
,VALUE("Last",-1,doNothing,noEvent)
//customizing a prompt look!
//by extending the prompt class
class altPrompt:public prompt {
public:
altPrompt(constMEM promptShadow& p):prompt(p) {}
Used printTo(navRoot &root,bool sel,menuOut& out, idx_t idx,idx_t len,idx_t) override {
return out.printRaw(F("special prompt!"),len);;
MENU(subMenu,"Sub-Menu",doNothing,noEvent,noStyle
,altOP(altPrompt,"",doNothing,noEvent)
,OP("Op",doNothing,noEvent)
,EXIT("<Back")
const char* constMEM hexDigit MEMMODE="0123456789ABCDEF";
const char* constMEM hexNr[] MEMMODE={"0","x",hexDigit,hexDigit};
char buf1[]="0x11";
MENU(mainMenu,"Main menu",doNothing,noEvent,wrapStyle
,OP("Op1",doNothing,noEvent)
,OP("Op2",doNothing,noEvent)
// ,FIELD(test,"Test","%",0,100,10,1,doNothing,noEvent,wrapStyle)
,SUBMENU(subMenu)
,SUBMENU(setLed)
,OP("LED On",myLedOn,enterEvent)
,OP("LED Off",myLedOff,enterEvent)
,FIELD(ledBacklight,"Backlight: ","",0,255,10,5,doNothing,noEvent,wrapStyle) // Menu option to set the intensity of the backlight of the screen.
,SUBMENU(selMenu)
,SUBMENU(chooseMenu)
//,OP("Alert test",doAlert,enterEvent)
,EDIT("Hex",buf1,hexNr,doNothing,noEvent,noStyle)
,EXIT("<Back")
// define menu colors --------------------------------------------------------
// {{disabled normal,disabled selected},{enabled normal,enabled selected, enabled editing}}
//monochromatic color table
#define Black RGB565(0,0,0)
#define Red RGB565(255,0,0)
#define Green RGB565(0,255,0)
#define Blue RGB565(0,0,255)
#define Gray RGB565(128,128,128)
#define LighterRed RGB565(255,150,150)
#define LighterGreen RGB565(150,255,150)
#define LighterBlue RGB565(150,150,255)
#define DarkerRed RGB565(150,0,0)
#define DarkerGreen RGB565(0,150,0)
#define DarkerBlue RGB565(0,0,150)
#define Cyan RGB565(0,255,255)
#define Magenta RGB565(255,0,255)
#define Yellow RGB565(255,255,0)
#define White RGB565(255,255,255)
const colorDef<uint16_t> colors[6] MEMMODE={
(uint16_t)Black,
(uint16_t)Black
(uint16_t)Black,
(uint16_t)DarkerBlue,
},//bgColor
(uint16_t)Gray,
(uint16_t)Gray
(uint16_t)White,
(uint16_t)White,
(uint16_t)White
},//fgColor
(uint16_t)White,
(uint16_t)Black
(uint16_t)Yellow,
(uint16_t)Yellow,
(uint16_t)Red
},//valColor
(uint16_t)White,
(uint16_t)Black
(uint16_t)White,
(uint16_t)Yellow,
(uint16_t)Yellow
},//unitColor
(uint16_t)White,
(uint16_t)Gray
(uint16_t)Black,
(uint16_t)Blue,
(uint16_t)White
},//cursorColor
(uint16_t)White,
(uint16_t)Yellow
(uint16_t)DarkerRed,
(uint16_t)White,
(uint16_t)White
},//titleColor
#define MAX_DEPTH 5
/// serialIn serial(Serial);
//MENU_INPUTS(in,&serial);its single, no need to `chainStream`
//define serial output device
idx_t serialTops[MAX_DEPTH]={0};
serialOut outSerial(Serial,serialTops);
#define GFX_WIDTH 240
#define GFX_HEIGHT 135
#define fontW 12
#define fontH 18
const panel panels[] MEMMODE = {{0, 0, GFX_WIDTH / fontW, GFX_HEIGHT / fontH}};
navNode* nodes[sizeof(panels) / sizeof(panel)]; //navNodes to store navigation status
panelsList pList(panels, nodes, 1); //a list of panels and nodes
idx_t eSpiTops[MAX_DEPTH]={0};
TFT_eSPIOut eSpiOut(gfx,colors,eSpiTops,pList,fontW,fontH+1);
menuOut* constMEM outputs[] MEMMODE={&outSerial,&eSpiOut};//list of output devices
outputsList out(outputs,sizeof(outputs)/sizeof(menuOut*));//outputs list controller
NAVROOT(nav,mainMenu,MAX_DEPTH,serial,out);
unsigned long idleTimestamp = millis();
//when menu is suspended
result idle(menuOut& o,idleEvent e) {
if (e==idling) {
// Show the idle message once
int xpos = gfx.width() / 2; // Half the screen width
gfx.fillScreen(Black);
gfx.setTextSize(5);
gfx.setTextColor(Yellow,Black);
gfx.setTextWrap(false);
gfx.setTextDatum(MC_DATUM);
gfx.drawString("IDLE", xpos, 50);
int getFontHeight = gfx.fontHeight();
gfx.setTextSize(2);
gfx.setTextColor(White,Black);
gfx.drawString("Long press a button", xpos, 90);
gfx.drawString("to exit", xpos, 110);
return proceed;
//config myOptions('*','-',defaultNavCodes,false);
void button_init()
btnUp.setLongClickHandler([](Button2 & b) {
// Select
unsigned int time = b.wasPressedFor();
if (time >= 1000) {
nav.doNav(enterCmd);
btnUp.setClickHandler([](Button2 & b) {
// Up
nav.doNav(downCmd); // It's called downCmd because it decreases the index of an array. Visually that would mean the selector goes upwards.
btnDwn.setLongClickHandler([](Button2 & b) {
// Exit
if (time >= 1000) {
nav.doNav(escCmd);
btnDwn.setClickHandler([](Button2 & b) {
// Down
nav.doNav(upCmd); // It's called upCmd because it increases the index of an array. Visually that would mean the selector goes downwards.
btnStart.setLongClickHandler([](Button2 & b) {
// Select
if (time >= 1000) {
Serial.print("menuBJ =");
Serial.print(menuBJ);
menuBJ = 1;
btnStart.setClickHandler([](Button2 & b) {
// Up
menuBJ = 1;
void button_loop()
// Check for button presses
btnUp.loop();
btnDwn.loop();
btnStart.loop();
//options=&myOptions;//can customize options
Serial.begin(115200); // Set Serial baudrate at 115200
// delay(500);
// while(!Serial);
Serial.flush();
Serial.print("ARDUINOMENU DEMO V");
Serial.print(PROG_VERSION);
Serial.println(" FOR LILYGO TTGO T-DISPLAY");
nav.idleTask=idle;//point a function to be used when menu is suspended
mainMenu[1].disable();
//outGfx.usePreview=true;//reserve one panel for preview?
//nav.showTitle=false;//show menu title?
//SPI.begin(); // Leave this commented or else there will be nothing shown on the screen.
gfx.init(); // Initialize the screen.
Serial.print("Configuring PWM for TFT backlight... ");
ledcSetup(pwmLedChannelTFT, pwmFreq, pwmResolution);
ledcAttachPin(TFT_BL, pwmLedChannelTFT);
Serial.println("DONE");
Serial.print("Setting PWM for TFT backlight to default intensity... ");
ledcWrite(pwmLedChannelTFT, ledBacklight);
gfx.setRotation(1); // Rotate display a quarter clockwise
gfx.setTextSize(2);
Serial.print("Showing bootlogo... ");
gfx.setSwapBytes(true);
gfx.pushImage(0, 0, 240, 135, bootlogo);
// delay(1000);
Serial.print("Initialize buttons... ");
button_init();
//delay(1000);
Serial.print("Initialize external led... ");
if(LED_CTRL > 0){
pinMode(LED_CTRL,OUTPUT);
digitalWrite(LED_CTRL,ledCtrl);
// delay(500);
else{
// delay(500);
Serial.println("NOT SET UP");
// delay(2000); // A little bit more delay so that you will be able to see the bootlogo.
Serial.println("- READY -");
gfx.fillScreen(Black); // Clear the screen to be ready to draw the menu
button_loop();
// nav.poll();//this device only draws when needed
if(menuBJ == 1)
nav.poll();
// External connected led
if(LED_CTRL > 0){ // Only set led state when a pinnumber for the external led has been provided.
// Set blacklight intenisty of screen
