Some thing happened strange when compiling in two laptops
Hi everyone,
I compiling the sketch below with error ofimage_util.h: No such file or directory' when I removed theimage_util.hfrom library, the reason I removed the image_util.h` from library is the compiling will get more and more errors with it. such as the ERROR MORE below.
but the sketch was done compiling on another laptop well without image_util.h , I didn't search out from library folder. why?
Thanks
Adam
#include <Arduino.h>
#include <WiFi.h>
/* Modify the following line according to your project name
   Do not forget to import the library using "Sketch">"Include Library">"Add .ZIP Library..."
#include "cats_and_dogs_inferencing.h"
#include "esp_http_server.h"
#include "img_converters.h"
#include "image_util.h"
#include "esp_camera.h"
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
#include "camera_pins.h"
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t camera_httpd = NULL;
httpd_handle_t stream_httpd = NULL;
const char* ssid = "your-ssid";
const char* password = "your-password";
dl_matrix3du_t *resized_matrix = NULL;
size_t out_len = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
ei_impulse_result_t result = {0};
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_240X240;  // config.frame_size = FRAMESIZE_UXGA; --this set works on CameraWebServer.
 // config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;  /// missed compared to CameraWebServer
 // config.fb_location = CAMERA_FB_IN_PSRAM;    /// missed compared to CameraWebServer
  config.jpeg_quality = 12;
  config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, 0); // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  startCameraServer();
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
int raw_feature_get_data(size_t offset, size_t out_len, float *signal_ptr)
  size_t pixel_ix = offset * 3;
  size_t bytes_left = out_len;
  size_t out_ptr_ix = 0;
  // read byte for byte
  while (bytes_left != 0) {
    // grab the values and convert to r/g/b
    uint8_t r, g, b;
    r = resized_matrix->item[pixel_ix];
    g = resized_matrix->item[pixel_ix + 1];
    b = resized_matrix->item[pixel_ix + 2];
    // then convert to out_ptr format
    float pixel_f = (r << 16) + (g << 8) + b;
    signal_ptr[out_ptr_ix] = pixel_f;
    // and go to the next pixel
    out_ptr_ix++;
    pixel_ix += 3;
    bytes_left--;
  return 0;
void classify()
  Serial.println("Getting signal...");
  signal_t signal;
  signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_WIDTH;
  signal.get_data = &raw_feature_get_data;
  Serial.println("Run classifier...");
  // Feed signal to the classifier
  EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false /* debug */);
  // Returned error variable "res" while data object.array in "result"
  ei_printf("run_classifier returned: %d\n", res);
  if (res != 0)
    return;
  // print the predictions
  ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
  for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
    ei_printf("    %s: \t%f\r\n", result.classification[ix].label, result.classification[ix].value);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
  ei_printf("    anomaly score: %f\r\n", result.anomaly);
#endif
static esp_err_t capture_handler(httpd_req_t *req) {
  esp_err_t res = ESP_OK;
  camera_fb_t * fb = NULL;
  Serial.println("Capture image");
  fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Camera capture failed");
    httpd_resp_send_500(req);
    return ESP_FAIL;
  // --- Convert frame to RGB888  ---
  Serial.println("Converting to RGB888...");
  // Allocate rgb888_matrix buffer
  dl_matrix3du_t *rgb888_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
  fmt2rgb888(fb->buf, fb->len, fb->format, rgb888_matrix->item);
  // --- Resize the RGB888 frame to 96x96 in this example ---
  Serial.println("Resizing the frame buffer...");
  resized_matrix = dl_matrix3du_alloc(1, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3);
  image_resize_linear(resized_matrix->item, rgb888_matrix->item, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, 3, fb->width, fb->height);
  // --- Free memory ---
  dl_matrix3du_free(rgb888_matrix);
  esp_camera_fb_return(fb);
  classify();
  // --- Convert back the resized RGB888 frame to JPG to send it back to the web app ---
  Serial.println("Converting resized RGB888 frame to JPG...");
  uint8_t * _jpg_buf = NULL;
  fmt2jpg(resized_matrix->item, out_len, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT, PIXFORMAT_RGB888, 10, &_jpg_buf, &out_len);
  // --- Send response ---
  Serial.println("Sending back HTTP response...");
  httpd_resp_set_type(req, "image/jpeg");
  httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
  httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
  res = httpd_resp_send(req, (const char *)_jpg_buf, out_len);
  dl_matrix3du_free(resized_matrix);
  free(_jpg_buf);
  _jpg_buf = NULL;
  return res;
static esp_err_t page_handler(httpd_req_t *req) {
  httpd_resp_set_type(req, "text/html");
  // httpd_resp_send(req, page, sizeof(page));
void startCameraServer() {
  httpd_config_t config = HTTPD_DEFAULT_CONFIG();
  httpd_uri_t capture_uri = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = capture_handler,
    .user_ctx  = NULL
  Serial.printf("Starting web server on port: '%d'\n", config.server_port);
  if (httpd_start(&camera_httpd, &config) == ESP_OK) {
    httpd_register_uri_handler(camera_httpd, &capture_uri);
    //httpd_register_uri_handler(camera_httpd, &page_uri);
  delay(10);
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, 80MHz"
Basic-Image-Classification_M:12:10: fatal error: image_util.h: No such file or directory
compilation terminated.
exit status 1
option enabled in File -> Preferences.
ERROR MORE:
In file included from C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_modified_sketch_956766\Basic-Image-Classification_M.ino:12:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\utility/image_util.h:9:10: fatal error: cef_image.h: No such file or directory
 #include "cef_image.h"
exit status 1
Error compiling for board AI Thinker ESP32-CAM.
Not sure what is going on here but …..You may have library folders in more than one location - Can happen when installing updates .
Have a look in properties as to where the library resides
