Somehow the "if" isn't responding to the condition
I'm trying to get my program to call a subroutine when the letter "i" is sent from the serial monitor. Here's the relevant code. I know the value of key is "i" because it prints it to the serial monitor the line before, but it still does not seem to trigger the if condition.
  pinMode(10,OUTPUT);  // Main Menu LED
  pinMode(11, OUTPUT); // Initiative LED
  delay(2000);
  FastLED.addLeds<WS2812, DATA_PIN, GRB>(leds, NUM_LEDS);
  char key="X";
  digitalWrite(10, HIGH);
  if (Serial.available()){
    key=Serial.read();
    Serial.println(key);
    if(key=="i"){
      Initiative();
void Initiative() {
  digitalWrite(10, LOW);
  digitalWrite(11, HIGH);
  delay(5000);
  char key="X";
  int order = 0;
  int battle[15]; //Initalize for 15 possible turns in a round of combat
  //Set Initiative Order ending when the key "0" is pressed
I separately sent each of the following values through the serial monitor, but even when I got to "i" it didn't send it to the subroutine.
5
5
6
4
1
i
I'm quite content to have it be some dumb thing like missing a ; somewhere, but what wouldn't even compile.
(The long end goal is to highlight players turns in initiative with an addressable LED strip when we play d&d)
'x' for single character, "z" for a string or null terminated character array. You cannot use == with strings.
Change your character to 'i' and try it.
Your code is incomplete. It will not compile. Please post entire program or MVCE
To compare a string you need strcomp().
Or you need to make it a char first.
key has "X" in it. That is an array of 2 characters (including \0) and does not fit into char.
You could set key to 'X'.
Like I said happy to have it be something simple. You've solved it.
Please mark the thread as "solved"
