Someone here who know's this display? Need dimensions!
Hi!
I want to buy this display: http://www.ebay.de/itm/230766694526?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
But there aren't any dimensions (width, height) of -module -visible display
Is someone here, who know's this display or has it? I couldn't find any informations - only that it is 1.8" large...
Thanks!
Greetings Morris
assuming it has standard connectors 0.1" apart you can measure it from the image.
9 holes (8 * 0.1 = 0.8") measures 6 cm on my screen, the image is 15x15 cm so the display is 2.5 x 0.8 = 2.0" on either side
distance between the holes = 13.5 cm ==> 1.8" if my math is not failing ...
does that make sense?
Given that the inch is defined as 2.54mm (a huge improvement over the original length of three barleycorns), I think your arithmetic is failing, quite badly. ;)
That’s just as I have also tried :slight_smile:
Nobody here, who has this display?
:) I mean the distance between the drilling holes is on the image (on my laptop) 13.5 cm which equals 1.8 inch on the real board all based upon the assumption that the distance between the connector holes is 0.1"
Can't you contact the manufacturer, it's website is on the PCB
robtillaart: Can't you contact the manufacturer, it's website is on the PCB
I made it. But unfortunately, I have received the reply until today.
[u]So the dimensions are:[/u] Board size: 2.0" x 1.8" (=50,8mm x 45,7mm) Visible LCD Area: 1.38" x 1.1" (=35mm x 28mm)
-> I bought one :)
Greetings Morris
Quote 13.5 cm ==> 1.8" if my math is not failing Given that the inch is defined as 2.54mm (a huge improvement over the original length of three barleycorns), I think your arithmetic is failing, quite badly.
Actually, I just measured a barleycorn, and it was 8.467mm, so I think you missed your decimal point by one.lol TomJ
