someone on UnoEuro or one.com
hi I'm still working with my little LOG project!
I have now had it running longer on my local server 6-7 months.
and running smoothly.
Now I would move it out on a web hosting.
and no now does nothing to work.
I've done it 100% the same as on the local server.
Why it will not work on a wephotel.
here a piece of code:
void data_sendt()
  // every thirty seconds this runs
  // Data der skal sendes til server
  // Tekst efter id= er inverterens serienummer eller ID
  // Tekst efter data= er data fra inverter. Data skal sendes i følgende rækkefølge:
  // temp, vac, vdc1, idc1, vdc2, idc2, etoday, etot, power
  sprintf(pageAdd,"/test_fil_1_ok_3.php?id=kimkimkim&temp=125,658,987",totalCount);
  if(!getPage(serverName,pageAdd)) Serial.print("Fail ");
  else Serial.print("Pass ");
  totalCount++;
  Serial.println(totalCount,DEC);
byte getPage(char* domainBuffer,char* page)
  int inChar;
  char outBuf[200];
  Serial.print("connecting...");
  if(client.connect(domainBuffer,80))// ændres til 8005 -> test eller 8000 -> data
    Serial.println("connected");
    sprintf(outBuf,"GET %s HTTP/1.0\r\n\r\n",page);
    client.write(outBuf);
    Serial.println("failed");
    return 0;
  // connectLoop controls the hardware fail timeout
  int connectLoop = 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
      Serial.write(inChar);
      // set connectLoop to zero if a packet arrives
      connectLoop = 0;
    connectLoop++;
    // if more than 10000 milliseconds since the last packet
    if(connectLoop > 10000)
      // then close the connection from this end.
      Serial.println("Timeout");
      client.stop();
    // this is a delay for the connectLoop timing
    delay(1);
  Serial.println("disconnecting.");
  // close client end
  client.stop();
  return 1;
void printTemperature(DeviceAddress deviceAddress)
  sensors.requestTemperatures();
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("tempC");
  Serial.println(tempC*100);
  tempc[0]=tempC*100;
void printbeholderThermometer(DeviceAddress deviceAddress)
  tempA = sensors.getTempC(deviceAddress);
  Serial.print("tempA");
  Serial.println(tempA*100);
  tempc[1]=tempA*100;
void printfyrThermometer(DeviceAddress deviceAddress)
  tempB = sensors.getTempC(deviceAddress);
  Serial.print("tempB");
  Serial.println(tempB*100);
  tempc[2]=tempB*100;
and here receives the code in php!
		$id=$_GET["id"];
	//echo $id;
    if (!is_dir( "data")) {
    mkdir("data");
	if (!is_dir( "data" . "/" . $id)) {
    mkdir("data" . "/" . $id);
	//mkdir("testing" . "/" . "data");
	$date = date("Y-m-d");
	$prefix=$id;
    $suffix=$date;
    $filename= "data" . "/" . $id . "/" .$suffix.".csv";
	echo $filename;
    define("LOG_FILE", $filename);
	if(!isset($_GET["temp"])) die("no value present");
	$temp = $_GET["temp"];
        $tempdel= explode(",", $temp);
        $tempdel[0]=$tempdel[0]/100;
        $tempdel[1]=$tempdel[1]/100;
        $tempdel[2]=$tempdel[2]/100;
        $tempdel[3]=$tempdel[3]/100;
        $tempdel[4]=$tempdel[4]/100;
        $tempdel[6]=$tempdel[6]-131;
      //DD-MM-YYYY TT:MM:SS
    $date=date("d-m-Y H:i", time());
	$file_handler = fopen(LOG_FILE, "a+");
	fwrite($file_handler, $date . "," . $tempdel[0]."," . $tempdel[1] ."," . $tempdel[2] ."," . $tempdel[3] ."," . $tempdel[4] ."," . $tempdel[5] ."," . $tempdel[6] ."\r\n");
	fflush($file_handler);
	echo "OK";
best Kim Jessen
What behavior do you get with it on the hosted webserver?
If you manually attempt to send data (ie, pretend to be the sketch, and make a request that should send data to it - if you can't easily produce the appropriate request, use advanced rest client for chrome), do you get the appropriate responses, or errors, or something else?
That will help you determine if the problem is on your site, or in your sketch.
Check applicable logs on the web server if the server is not behaving correctly.
My suspicion - based on very little evidence - is that the problem is file permissions (ie, webserver process doesn't have write access to the log file you're trying to write to).
there will be no error messages
it just does not work.
If I use the browser and writes domain data string
so it works. for example.
domain.dk/test_fil_1_ok_3.php?id=kimkimkim&temp=125,658,987
It seems the file is created and the data written to the file.
both on the local server and the hosted domain.
No one has an idea
