Someone Please I need Help!!
CAN SOMEONE HELP ME!!!
I have been trying to upload the Blink File to an “Arduino UNO” and sense I upgraded the Arduino Software to Ver. 1.6, On my Windows 7, I have been having the same problem for a long time and can’t figure it out. Attached is the error message I get all the time. :zipper_mouth_face:
Arduino UNO Error Message.txt (19.6 KB)
Have you tried running as administrator? What com port is your device connecting as? You may need to update the USB drivers. Check in device manager for your Arduino com port when the device is connected.
If you load the Control Panel and select Device Manager, what does your Ports show if your Arduino is attached to the USB cable? If not shown, does running the appropriate (32 or 64 bit) ?.EXE under the Drivers subdirectory change it?
