i get some problems when i write-read structure data to i2c 24LC64 eeprom
how EEPROM I2C Write Anything – Apex Logic seems not to or return nothing, i probe my code, but something go wrong with 4th byte conversion
please anybody give me a little help?
best regards, pescadito.
// my probe code
// Use the I2C bus with EEPROM 24LC64
#include <Wire.h> //I2C library
struct edata_t {
unsigned long i; // 4 bytes from 0 to 4,294,967,295 (2^32 - 1).
unsigned long millitime; // 4
float temperature; // 4 bytes 6-7 decimal digits of precision
int32_t pressure; // 4 bytes (32-bit signed type)
float altitude; // 4 bytes
float altidudestd; // 4 bytes
} edata;
byte ebuffer[] = " 0123456789 123456789 123"; // some temp buffer
Wire.begin(); // initialise the connection
Serial.println("Writing...");
int ilines = 9;
for(int i = 1; i <= ilines; i++) {
edata.i = i;
edata.millitime = millis();
edata.temperature = 123.45;
edata.pressure = 123456;
edata.altitude = 321.09;
edata.altidudestd = 333.33;
ebuffer[0] = lowByte(edata.i);
ebuffer[1] = lowByte(edata.i >> 8);
ebuffer[2] = lowByte(edata.i >> 16);
ebuffer[3] = lowByte(edata.i >> 24);
ebuffer[4] = lowByte(edata.millitime);
ebuffer[5] = lowByte(edata.millitime >> 8);
ebuffer[6] = lowByte(edata.millitime >> 16);
ebuffer[7] = lowByte(edata.millitime >> 24);
// ebuffer[8] = etc....
delay(10);
i2c_eeprom_write_page(0x50, i*24, (byte *)ebuffer, sizeof(ebuffer)); // write to EEPROM
Serial.print("i "); Serial.print(i);
Serial.print(", ei "); Serial.print(edata.i);
Serial.print(", t "); Serial.print(edata.millitime); Serial.println(". ");
Serial.println("Writed.");
Serial.println("");
delay(3000);
Serial.println("Reading...");
int ilines = 9;
i2c_eeprom_read_buffer(0x50, i*24, (byte *)ebuffer, sizeof(ebuffer));
edata.i = (ebuffer[3] << 24) | (ebuffer[2] << 16) | (ebuffer[1] << 8) | ebuffer[0];
edata.millitime = (ebuffer[7] << 24) | (ebuffer[6] << 16) | (ebuffer[5] << 8) | ebuffer[4];
Serial.println("Readed...");
Serial.println(" ");
delay(10000);
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddresspage >> 8)); // MSB
Wire.write((int)(eeaddresspage & 0xFF)); // LSB
byte c;
for ( c = 0; c < length; c++)
Wire.write(data[c]);
Wire.endTransmission();
void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length ) {
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.requestFrom(deviceaddress,length);
int c = 0;
for ( c = 0; c < length; c++ )
if (Wire.available()) buffer[c] = Wire.read();
// that returned this serial output:
Writing...
i 1, ei 1, t 0.
i 2, ei 2, t 13.
i 3, ei 3, t 26.
i 4, ei 4, t 39.
i 5, ei 5, t 53.
i 6, ei 6, t 66.
i 7, ei 7, t 79.
i 8, ei 8, t 93.
i 9, ei 9, t 106.
Writed.
Reading...
i 1, ei 1, t 0.
i 2, ei 2, t 13.
i 3, ei 3, t 26.
i 4, ei 14391, t 12849. // here some gabarish
i 5, ei 5, t 53.
i 6, ei 6, t 66.
i 7, ei 7, t 79.
i 8, ei 14391, t 12849. // here some gabarish
i 9, ei 9, t 106.
Readed...
strange but i get similar result when use a second probe code
// another example
#include "MyTypes.h"
edata_t edata;
i2c_eeprom_write_edata(0x50, i*24, &edata); // write to EEPROM
edata = i2c_eeprom_read_edata(0x50, i*24); //, edata); // write to EEPROM
void i2c_eeprom_write_edata( int deviceaddress, unsigned int eeaddresspage, edata_t* ed ) {
unsigned long uBufSize = sizeof(edata_t);
byte pBuffer[uBufSize];
memcpy(pBuffer, &ed, uBufSize);
edata_t i2c_eeprom_read_edata( int deviceaddress, unsigned int eeaddress) {
edata_t ed;
Wire.requestFrom(deviceaddress,uBufSize);
for (int i = 0; i < uBufSize; i++ )
if (Wire.available()) pBuffer[i] = Wire.read();
memcpy(&ed, pBuffer, uBufSize);
return ed;
// that return a similar gabarish:
Writing...
i 1, ei 1, t 0.
i 2, ei 2, t 10.
i 3, ei 3, t 21.
i 4, ei 4, t 31.
i 5, ei 5, t 43.
i 6, ei 6, t 53.
i 7, ei 7, t 64.
i 8, ei 8, t 83.
i 9, ei 9, t 103.
Writed.
Reading...
i 1, ei 1, t 0.
i 2, ei 2, t 13.
i 3, ei 3, t 26.
i 4, ei 540620855, t 875770417. //here some gabarisn
i 5, ei 5, t 53.
i 6, ei 6, t 66.
i 7, ei 7, t 79.
i 8, ei 540620855, t 875770417. //here some gabarisn
i 9, ei 9, t 106.
Readed.
