Something HANGS
I am finding some times Arduino UNO hanging out/ No operation found after pressing resetting button also.
Attaching sketch used for Ultrasonic Sensor.
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 16) { // This is where the LED On/Off happens
digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
digitalWrite(led2,LOW);
else {
digitalWrite(led,LOW);
digitalWrite(led2,HIGH);
if (distance >= 25 || distance <= 0){
Serial.println(“Out of range”);
else {
Serial.print(distance);
Serial.println(" cm");
Can somebody help me
@V_R_Kudale
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
I loved the subject line of this post :slight_smile:
(deleted)
