I wanted to share something I discovered while experimenting with common anode RGB LED and Feather Huzzah. I was using an example sketch that was intended for an Arduino Uno using the analogWrite function. The example was based on duty cycle of 255 which is default for the function. When it ran the RGB LED did not change to the expected colors (Red, Green, Blue, Yellow, Purple then Aqua) but instead changed to few shades of lite blue. Initially thought the pins I was using (14, 12, and 13) were not capable of PWM but I found documentation that all but pin 16 are capable. I didn't find any documentation on the Feather Huzzah that stated what its frequency is until I found the Adafruit IO sketch that showed using 1023. Voila.
Adafruit Arduino - Lesson 3. RGB LED
For Arduino PWM duty cycle is 0-255 but for Feather Huzzah its 0-1023
int redPin = 14;
int greenPin = 12;
int bluePin = 13;
//uncomment this line if using a Common Anode LED
#define COMMON_ANODE
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
setColor(1023, 0, 0); // red
setColor(0, 1023, 0); // green
setColor(0, 0, 1023); // blue
setColor(1023, 1023, 0); // yellow
setColor(80, 0, 80); // purple
setColor(0, 1023, 1023); // aqua
void setColor(int red, int green, int blue)
#ifdef COMMON_ANODE
red = 1023 - red;
green = 1023 - green;
blue = 1023 - blue;
#endif
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
