Something is wrong with setup() and loop()
So I keep getting these errors, and I cannot understand why… :frowning:
It seems that the code has errors only in core stuff like OUTPUT, HIGH, and digitalWrite
Errors:
Arduino_RFID_Sensor_Fun.cpp: In function 'void setup()':
Arduino_RFID_Sensor_Fun:12: error: 'Serial' was not declared in this scope
Arduino_RFID_Sensor_Fun:13: error: 'OUTPUT' was not declared in this scope
Arduino_RFID_Sensor_Fun:13: error: 'pinMode' was not declared in this scope
Arduino_RFID_Sensor_Fun:14: error: 'LOW' was not declared in this scope
Arduino_RFID_Sensor_Fun:14: error: 'digitalWrite' was not declared in this scope
Arduino_RFID_Sensor_Fun.cpp: In function 'void loop()':
Arduino_RFID_Sensor_Fun:29: error: 'HIGH' was not declared in this scope
Arduino_RFID_Sensor_Fun:29: error: 'digitalWrite' was not declared in this scope
Arduino_RFID_Sensor_Fun:30: error: 'delay' was not declared in this scope
Arduino_RFID_Sensor_Fun:31: error: 'LOW' was not declared in this scope
Arduino_RFID_Sensor_Fun:36: error: 'Serial' was not declared in this scope
Arduino_RFID_Sensor_Fun.cpp: In function 'void ReadRFIDTag()':
Arduino_RFID_Sensor_Fun:42: error: 'Serial' was not declared in this scope
Arduino_RFID_Sensor_Fun:65: error: 'HIGH' was not declared in this scope
Arduino_RFID_Sensor_Fun:65: error: 'digitalWrite' was not declared in this scope
Arduino_RFID_Sensor_Fun:66: error: 'delay' was not declared in this scope
Arduino_RFID_Sensor_Fun.cpp: In function 'void AuthDeauthTag(char*)':
Arduino_RFID_Sensor_Fun:93: error: 'Serial' was not declared in this scope
Arduino_RFID_Sensor_Fun:98: error: 'Serial' was not declared in this scope
For this code:
//---------- RFID Stuff -----------\\
int  val = 0;
char code[10];
int bytesread = 0;
bool Auth;
// Tag variables
char Tag1[10] = {'1','2','0','0','0','C','8','9','8','5'}; // What Tag 1 returns on Serial
char Tag2[10] = {'1','2','0','0','0','C','8','B','0','8'}; // What Tag 2 returns on Serial
  Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(2, LOW);                  // Activate the RFID reader
  Serial.println("Scan your RFID Tag");
  while(!(Serial.available() > 0))
    // Wait for Serial to return values (A.K.A. Wait for the card)
  ReadRFIDTag();
  AuthDeauthTag(Tag1);
  if(Auth == true)
    digitalWrite(13, HIGH);
    digitalWrite(13, LOW);
    Serial.println("Done");
void ReadRFIDTag()
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10)
    {                                   // check for header
      bytesread = 0;
      while(bytesread<10)
      {                                  // read 10 digit code
        if( Serial.available() > 0)
          val = Serial.read();
          if((val == 10)||(val == 13))
          {                              // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10)
      {                                  // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
      digitalWrite(2, HIGH);             // deactivate the RFID reader for a moment so it will not flood
      delay(1500);                       // wait for a bit
      //digitalWrite(2, LOW);         // Activate the RFID reader
bool isArrayEqual(char array1[10], char array2[10])
  for(int i = 0; i < 10; i++)
    if(array1[i] == array2[i])
      // Continue on
      return false;
  return true;
void AuthDeauthTag(char ID[10])
  if(isArrayEqual(code, ID))
    Serial.println("Autherized");
    Auth = true;
    Serial.println("Booted");
    Auth = false;
Help?
Change it to a pde extension, or add #include<WProgram.h> at the top.
Just remove the comment from the first line of the file - it messes up the preprocessor.
EDIT: Actually, it seems like it's just the backslash in the comment that's problematic; comments without the backslashes are fine.
Is this documented somewhere?
[quote author=Professor Chaos link=topic=63719.msg463524#msg463524 date=1307821692] ...it seems like it's just the backslash in the comment that's problematic; comments without the backslashes are fine.[/quote]
In C and C++ code (certain other languages, too), if the last character on a line is a backslash (the last character before the newline, that is), the following line is treated as a continuation. The C++ sketch generated by Arduino puts #include "Wprogram.h" after initial comments and before the function prototypes, so the first two lines of the generated sketch are
#include "WProgram.h"
The C++ preprocessor stitches the two lines together into a single line like this:
//---------- RFID Stuff -----------\#include "WProgram.h"
so that the #include stuff is now part of the comment. The C++ preprocessor throws away all comments so the compiler never sees the #include "Wprogram" line, and that's what causes these particular errors.
Ways to avoid problems like this:
1. Don't write comments with backslash as the final character on the line. (Note that blank characters after a '\' at the end are absorbed by some compiler preprocessors, including the one for avr-gcc used by Arduino, so you can't expect to improve it by just adding a space or two after the backslash.)
or
2. If you feel that you absolutely must have a backslash as the last character of a comment, leave at least one blank line or a non-backslashed one-line comment line (or some such thing) between the backslashed comment and anything significant.
These little rules apply to all C and C++ programs, not just Arduino sketches. These apply to any part of a program, not just the first line. (It's not an Arduino thing; it's a C/C++ thing.)
Regards,
Dave
Thank you all for helping! Removing the back slashes worked great!
