after 'sprintf' command ohsk value changes from 0 to 50, 51,52,...57,12337 with each trigger.
if loop is triggered with a button on arduino,
hacscont = digitalRead(hac_trg);
if (hacscont != ohsk)
{Serial.println(ohsk);
if
(hacscont == HIGH) {hacs++;
char chacs[5];
String stra(hacs);
stra.toCharArray (chacs,5);
char charchacs[5];
String strx(chacs);
strx.toCharArray(charchacs,5);
sprintf(HCSson,"%s %s",HCS,charchacs);
Serial.println("AFTER THAT"); //!!!!!!
Serial.println(ohsk); //!!!!
delay (50);
mqttClient.setServer(server, 1883);if (mqttClient.connect("Counter 1")){ Serial.println("Connected to server -------HCS"); mqttClient.setCallback(subscribeReceive);}
delay (50) ;
mqttClient.subscribe("Counter 1");if(mqttClient.publish("Counter 1", HCSson)){ Serial.println("Message Sent-------HCS");}
delay(50);
ohsk = hacscont;
I have three similar if loops with exact same pattern runs regularly.
I don't know if is there something I'm missing.
Serial monitor screen capture is attached
You need to show more code. We have no idea how ohsk is declared.
Please - use the auto-format tool before posting code.
AWOL:
That's gotta be a troll. Nobody writes code like that. Someone obviously went through and removed all the line breaks and then added them back in at random.
Effective use of comments:
Perehama:
Sorry for the format
Yes I've deleted irrelevant lines beacause I wanted to leave the required lines, it was not a good idea.
The code is attached
My problem is at line 203
I've added serial.println to every line at this loop beacause I wanted to see when ohsk value goes to 50's
I'll be happy if you can help me
Thank You
for_forum_2.ino (26.6 KB)
char HCSson [15];
const char* HCS = "Wrong status :"; //
char charchacs[5];
sprintf(HCSson, "%s %s", HCS, charchacs);
The HCSson array is not large enough to hold the data being put in it so other data is being overwritten
UKHeliBob:
Thank You so much for your support.
Changed to:
char HCSson [25];
And all good now.
If you had used snprintf, as I suggested, you would have found this problem much sooner and your program would fail much more gracefully.
