Hello,
i’m usign arduino uno with a sim808 module; i’d like to get the phone number of incoming calls and this is my sketch
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
char gprsBuffer[64];
char *s = NULL;
char *p1;
char *phone;
char my[] = "+39xxxxxxxxx"; // it is the default phone number
char tel[20];
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0;
// constants won't change:
long interval = 10000;
#define PIN_TX 3
#define PIN_RX 2
SoftwareSerial mySerial(PIN_TX,PIN_RX);
DFRobot_SIM808 sim808(&mySerial);//Connect RX,TX,PWR,
void ring(){
//******** Wait serial data *************
if(sim808.readable()){
sim808_read_buffer(gprsBuffer,32,DEFAULT_TIMEOUT);
//Serial.println(gprsBuffer);
p1 = strstr(gprsBuffer, "+39");
if(NULL != p1) {
//Serial.println(p1);
//memset(pippo, '\0', sizeof(tel));
strncpy (tel, p1, 20);
Serial.println(p1);
Serial.println(tel);
//strncpy(tel,NULL, 100);
phone = tel;
Serial.println(phone);
//p1 = strstr(gprsBuffer, " \"+ ");
//if (p1 != NULL) {
//Serial.print(p1);
//p2 = strstr(p1, " \" ");
//if (p2) Serial.print(p2);//printf("%.*s\n", p2 - p1 - 6, p1 + 6);
//************** Detect the current state of the telephone or SMS ************************
if(NULL != strstr(gprsBuffer,"RING")) {
sim808.answer();
sim808_clean_buffer(gprsBuffer,32);
mySerial.begin(9600);
phone = my;
pinMode(13, OUTPUT);
while(!sim808.init())
Serial.print("Sim808 init error\r\n");
delay(3000);
Serial.println("Init Success, please call me!");
//Serial.println(phone);
unsigned long now = millis();
while (millis() < now + interval) {
ring();
I noticed that on the first two call the number stored in *p1, tel and *phone is correctly showed, at the third it loses some numbers, from the fouth on nothing is display, is it a problem with char array or pointers in which the phone number is stored? I cannot figure out…
If "+39" is found in the buffer, "sim808_clean_buffer(gprsBuffer, 32);" is never called. Should it be called?
Thanks for your answer, I don't know if this is the issue (also the second if with buffer clean should be called during RING=call) , but I'll try to indent the first if...+39 inside the "if(NULL != strstr(gprsBuffer,"RING"))"
no way, this is the modified code
#define MESSAGE_LENGTH 160
char *s = NULL;
char *p1;
char *phone;
char my[] = "+393317943514";
char tel[20];
#define PIN_TX 3
#define PIN_RX 2
void ring(){
if(NULL != p1) {
Serial.println(p1);
phone = tel;
//if (p1 != NULL) {
//Serial.print(p1);
sim808.answer();
phone = my;
delay(3000);
ring();
but the telephone number is showed randomly (only on first and, sometimes, second call, then nothing)
ring();
You only call ring() for seven seconds. How many calls do you expect? Why the time limit?
it's only a test to see if i can get and store the phone number that is calling
Be careful using strncpy(), it does not append a terminating null if the source if longer than the number of characters you are copying.
How do you know that you receive three or more calls in that period?
That's a good point, but the OP sets up a 64 character buffer, and then only deals with 32 characters or less during the sketch. I think he guarantees a terminating null from the initialization.
