something's wrong with my ethernetV2_0 sketch
i’m expecting the arduino to keep reading my inputs but only takes the first one that satisies one of the ‘if’ booleans.
#include <SPI.h>
#include <EthernetV2_0.h>
#include <string.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
IPAddress ip(192,168,1, 177);
IPAddress gateway(192,168,1, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean gotAMessage = false; // whether or not you got a message from the client yet
#define W5200_CS  10
#define SDCARD_CS 4
  pinMode(7,OUTPUT);
  pinMode(9,OUTPUT);
  // start the Ethernet connection:
  Serial.println("Trying to get an IP address using DHCP");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // initialize the ethernet device not using DHCP:
    Ethernet.begin(mac, ip, gateway, subnet);
  // print your local IP address:
  Serial.print("My IP address: ");
  ip = Ethernet.localIP();
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(ip[thisByte], DEC);
    Serial.print(".");
  // start listening for clients
  server.begin();
  // wait for a new client:
  // when the client sends the first byte, say hello:
  if (client) {
    if (!gotAMessage) {
      Serial.println("We have a new client");
      client.println("Hello, client!");
      gotAMessage = true;
   char tempp;
     tempp = client.read();
     if(tempp=='a')
          server.println("");
          analogWrite(7,80);
          server.println("\nled on");
     else if(tempp=='c')
          server.println("");
          analogWrite(7,0);
          server.println("\nled off");
     else if(tempp=='b')
          server.println("");
          analogWrite(9,150);
          server.println("\nbuzzer on");
     else if(tempp=='d')
          server.println("");
          analogWrite(9,0);
          server.println("buzzer off");
     tempp = '\0';
You are reading only one character as far as I can tell, and you are not closing the connection. Here is web server code that is more complete. Take what you need from it. http://playground.arduino.cc/Code/WebServerST
