Sometimes after reboot, Yun bridge will not connect between Linux and Microcontroller.
I was thinking maybe it's related to the USB Adapter not having enough amp ... while it seems to make a difference which USB to 120V power adapter I am using (some seem to make this behavior worse), I still can't make the problem go 100% away (tried 4 diff USB > 120V adapters)...
Is anyone experiencing this kind of behavior where the Serial1 between the Linux and Micro Controller doesn't come up and you need to reboot again?
I am using Arduino Yun Rev 4 with latest software build
I hope this helps someone.
you need to use this code.
Serial1.begin(9600); // Set the baud.
while (!Serial1) {}
// Wait for U-boot to finish startup. Consume all bytes until we are done.
do {
while (Serial1.available() > 0) {
Serial1.read();
} while (Serial1.available() > 0);
