hi, i am on a "stove oven Heating project. " a servo controls air inlet of a oven. it works proper in most case but sometimes ( i connot understand in which case) it goes crazy about 1-2 sec. i mean it sweeps 20,160,50,90.... etc degrees very rapidly like 10 ms for each degree. of course i picked theese angles randomly. and it do it approximatelly every 30 sec. i try to solve this problem by adding delay(2000) of each servo control command but it didnt help. my servo work proper when u make simple project or examples.
i added my servo video as gif
i am noob and if you have any comment on my code i want to hear them.
could you pls help me? thank you
#include <Wire.h>
#include <FaBoLCD_PCF8574.h>
FaBoLCD_PCF8574 lcd;
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
#include<Servo.h>
Servo Myservo;
const int LED_RED=9; //Red LED
const int LED_GREEN=8; //Green LED
const int RELAY=12; //Lock Relay or motor
const int up_key=7;
const int down_key=6;
// #define up_key 8
// #define down_key 7
// #define LED_RED 9
// #define LED_GREEN 8
int SetPoint=25;
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 1000; //ortalama sıcaklık hesaplama süresi
unsigned long previousMillis2 = 0; // will store last time LED was updated
const long interval2 = 10000; //wait time before make new action
double T0=20;//anlık sıcaklık
double T1=20.5;//interval önceki sıcaklık
double T2=20.6;
int step1=10; //step size for inc
int step2=20;
int pos=90;
//ortalama sıcaklık için
const int numReadings = 60;
double readings[numReadings]; // array the readings from the analog input
int readIndex = 0; // the index of the current reading
double average = 20.5;
double total = numReadings*average;// the running total
const int numReadings2 = 10;
double readings2[numReadings2]; // 2. sayaç
int readIndex2 = 0; // 2.sayaç
double average2 = 20.7;
double total2 = numReadings2*average2; // 2.sayaç
//test-----------------------
int a=0;
//test----------
pinMode(LED_RED,OUTPUT);
pinMode(LED_GREEN,OUTPUT);
pinMode(RELAY,OUTPUT);
pinMode(up_key,INPUT);
pinMode(down_key,INPUT);
digitalWrite(up_key,HIGH);
digitalWrite(down_key,HIGH);
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("sicaklik=");
lcd.setCursor(0, 1);
lcd.print("ayar=");
dht.begin();
sensor_t sensor;
digitalWrite(LED_GREEN,HIGH); //Green LED Off
digitalWrite(LED_RED,LOW); //Red LED On
digitalWrite(RELAY,LOW); //Turn off Relay
Myservo.attach(10);
//ortalama sıcaklık
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 20;}
for (int thisReading2 = 0; thisReading2 < numReadings2; thisReading2++) {
readings2[thisReading2] = 20;}
delay(2000);
void Turnoff(){
Myservo.write(0);
delay(3000);
digitalWrite(RELAY,LOW); //Turn off heater
digitalWrite(LED_GREEN,HIGH); //Turn on Green LED
void Turnon(){
Myservo.write(170);
delay(3000);
digitalWrite(RELAY,HIGH); //Turn on heater %100
digitalWrite(LED_GREEN,LOW);
digitalWrite(LED_RED,HIGH); //Turn on RED LED
void servopos(int position){
Serial.print("servopos cagirildi---+++--+++---:");Serial.println(position);
Myservo.write(position);
delay(2000);
digitalWrite(RELAY,HIGH); //Turn on heater %50
//Buton led test
// if(digitalRead(up_key)==1){
// digitalWrite(LED_RED,HIGH);
// digitalWrite(LED_GREEN,HIGH);
// else{
// digitalWrite(LED_RED,LOW);
// digitalWrite(LED_GREEN,LOW);
// if(digitalRead(down_key)==1){
// else{
//Servo test
// Myservo.write(a);
// delay(1000);
// if (a<180) a=a+20;
//dht lcd yazdırma
// float temp=dht.readTemperature();
// float hum=dht.readHumidity();
// lcd.setCursor(7,0);
// lcd.print(temp);
// lcd.setCursor(7,1);
// lcd.print(hum);
// Serial.println(temp);
// Serial.println(hum);
Serial.print("pos");Serial.println(pos);
Serial.print("T0");Serial.println(T0);
Serial.print("total");Serial.println(total);
Serial.print("T1");Serial.println(T1);
Serial.print("readings");
for (int i = 0; i < 30; i++) Serial.print(readings[i]);
Serial.println("------------");
// test sonu------------------
T0=dht.readTemperature();
//Ortalama sıcaklık T1 array hesaplama
if (currentMillis - previousMillis >= interval)
Serial.print("calc_t1 cagirildi read index:");Serial.println(readIndex);
total = total - readings[readIndex];
readings[readIndex] = T0;
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings)
readIndex = 0;
T1 = float(total) / float(numReadings);
//ortalama sıcaklık için t2 hesaplama. anlık karar verdiği için hesaplandı
Serial.print("calc_t2 cagirildi read index:");Serial.println(readIndex2);
total2 = total2 - readings2[readIndex2];
readings2[readIndex2] = T0;
total2 = total2 + readings2[readIndex2];
readIndex2 = readIndex2 + 1;
if (readIndex2 >= numReadings2)
readIndex2 = 0;
T2 = float(total2) / float(numReadings2);
//lcd ön işlem
lcd.setCursor(0,0);
lcd.print("oda:"); //Do not display entered keys
lcd.setCursor(4,0);
lcd.print(T0);
lcd.setCursor(10,0);
lcd.print(T2);
lcd.setCursor(15,0);
if (T2>T1) lcd.print("+");
if (T1>T2) lcd.print("-");
/* code */
//Get user input for setpoints
if(SetPoint>15)
SetPoint--;
if(SetPoint<30)
SetPoint++;
//Display Set point on LCD
lcd.setCursor(0,1);
lcd.print("set:");
lcd.print(SetPoint);
lcd.print(" T1:");
lcd.setCursor(11,1);
lcd.print(T1);
//Check T2 is in limit
if(T2 > (SetPoint+4))
Turnoff();
else if (T2<(SetPoint-4))
Turnon();
//AKILLI KARŞILAŞTIRMA
//eğer oda istenenden biraz sıcaksa
if ((T2>(SetPoint)) && (currentMillis - previousMillis2 >= interval2) )
//ve oda ısınıyorsa
if ((T1<T2)&&(pos>step1))
pos=(pos-step1);
Serial.print("biraz sicak");Serial.println(pos);
servopos(pos) ;
//ve oda soğuyorsa
previousMillis2 = currentMillis;
//eğer oda istenenden biraz soğuksa
if ( (T2<SetPoint) && (currentMillis - previousMillis2 >= interval2) )
//VE ODA SOĞUYORSA
if ((T1>T2)&&(pos<170))
pos = (pos+step1);
Serial.print("biraz soguk");Serial.println(pos);
servopos(pos);
delay(100); //Update at every
servofail2.47.zip (153.5 KB)
