Somthing to run, only when called
Hello
Is it possible to make somthing out of the void loop() ? etc. somthing like "void writeSd()", that can save data to a SD-card. If that is possible, how do i call the WriteSd() from the loop, ONLY one time??. I my mind it is not nessecary to read the whole loop, when the program has to write to the SD-card, ect. every 10 minutes. This will only cost on the performance.
Sorry for my bad english, but this is a fantastic help-site, for learning.
Yes, it is possible to develop, and call, functions.
Use a global, boolean, variable, initially set to true. Test that variable in loop(). If it is true, call the function and set the variable to false.
bool needToLog = true;
   if(needToLog)
      writeSd();
      needToLog = false;
Thanks PoulS
When I´m doing:
if (log1 = true) {
      Serial.print(F("  "));
      Serial.print(WattSD);
      char filename[] = "LOG_096.txt";
      if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
         if (!myFile.open(filename, O_RDWR | O_CREAT | O_AT_END)) {
              sd.errorHalt("SDFAILD");
      log1 = false;
      WriteSd();
I got the error that WriteSd(); isen´t declared in the scoop. How to do that??
if (log1 = true) {
==, not =, though the == true part is not required.
You need to create that function:
void WriteSd()
  // Probably want to do something
THANKS Poul!!!!
My bad was little vs. big letters (WriteSd was anthoer place been to writeSd).... Sorry my bad..!
