Sonar distance through Arduino converted to speech...
Not sure if this is possible but I would like to use a sonar module coupled to an arduino board (already done) and convert the output to speech. I am working on a device that would be able to help a blind person hear the distance to an object in front of the sonar module. This is the basic project concept. Any help would be much appreciated...
A bit tricky. Get a wave shield and record the numbers zero to twenty. Also the numbers thirty, forty and so on up to a hundred. Then write software to convert a number into one or more of these samples.
Try out the Talkie library. It uses software-only speech synthesis and is very easy to use, for example to convert numbers into speech. GitHub - going-digital/Talkie: Speech library for Arduino Some of the speech synthesis codings sound better than others, so experiment!
You can listen to my "weather station" example. (slightly modified for a non-Arduino Pololu Orangutan) here: Pololu - Speech synthesis with the Orangutan SV-328
You will need an audio amplifier of some sort connected to the port pin. Don't try to connect a speaker to a port pin, as some do, as you might damage the pin or even the Arduino.
Just as a thought, converting the distance to an audio output frequency would be trivial to implement for a proof-of-concept.
YMMV, but I would have thought a varying tone giving a continuous indication of the distance might actually be easier to use than a voice reading out the distance at intervals, anyway. (In other words, the quick hack might actually be the better solution.)
I now have most of the hardware for the project and after looking at the responses have decided to pursue the wave shield suggestion post. I have a HC-SR04 sensor, a arduino nano for the processor, still awaiting the adafruit wave shield.
Because the sonar sensor arrangement is not exactly what I need I am considering removing the round hardware from the HC-SR04 board and using it in a remote arrangement that I plan to build myself. Does anyone have any experience with this type of thing? It appears that those can be de-soldered, I plan to use shielded wire (approximately 4 feet) to re-connect them to the board.
Thanks for your Help..
