Sonar sensor help
hi I have to operate an ultrasonic sensor via arduino without using libraries and with interrupts! I did this code, can anyone tell me where it is wrong?
volatile long distance=0;
volatile long duration=0;
volatile long start=0;
volatile long stop=0;
volatile boolean measured=true;
#define echoPin 2
#define trigPin 7
pinMode(echoPin, INPUT);
pinMode(trigPin, OUTPUT);
attachInterrupt (0, detect, RISING);
if(measured){
digitalWrite(trigPin,LOW);
delayMicroseconds(10);
digitalWrite(trigPin, HIGH);
start=millis();
Serial.print("start:");
Serial.println(start);
distance=((stop-start)*0.03438)/2;
Serial.print("distanza:");
Serial.println(distance);
void detect(){
if(digitalRead(trigPin)==LOW){
measured=true;
stop=millis();
measured=false;
Please edit your post to add code tags, as described in the "How to use this forum" post.
You need to tell us if something seems to be wrong, and why you think so.
