I bought two cheap Hobbyking sonar sensors last year.
The arduino could read very accurate distance values with the newPing library.
Now I needed them for a project and they seem to be broken.
When I connect the triger-Pin I can hear some silent clicking. (which should be a positive sign)
The values on the serial Monitor are changing between constantly and the real distance doesnt seem to influence them.
I tested it with different example codes from different websites on 3 different arduinos and 2 sensors.
I just cant believe that those sensors are broken, they worked once and were stored safely.
Well, sometimes the simplest things can cause the biggest problems.
One of my jumper wires had a bad contact.
While I tried it with different PCs, Arduinos and Modules I didn't think of that.
It may be the cause for a lot of seemingly broken hardware lately.
