sonar srf08
Hello, I have a probleme with my Serial.print.
Nothing is displayed on my monitor, not even my println or my distance someone could help me.
This is my program:
#include <Wire.h>
#define srfAddress 0x70                           // Address of the SRF08
#define cmdByte 0x00                              // Command byte
#define lightByte 0x01                            // Byte to read light sensor
#define rangeByte 0x02                            // Byte for start of ranging data
void setup(){
 Wire.begin();                                   // Initialize the I2C bus
 Serial.begin(115200);                           // Initialize the serial connection
 delay(100);                                     // Waits to make sure everything is powered up before sending or receiving data
 Wire.beginTransmission(srfAddress);             // Start communicating with SRF08
 Wire.write(0xFF);    // <-- CHANGE RANGE TO THE MAX AVAILABLE: 11 meters
 Wire.write(0x25);   // <-- THIS IS FOR THE MAX GAIN
 Wire.endTransmission();
void loop(){
 //int rangeData = getSoft();                     // Calls a function to get software version
 int rangeData = getRange();                      // Calls a function to get the range data
 int lightData = getLight();                      // Calls a function to get the light data
 Serial.print("Range: ");
 Serial.print(rangeData);
 Serial.println("cm");
 Serial.print("Light: ");
 Serial.print(lightData);
 Serial.println("");
 delay(100);                                      // Wait before looping
int getRange(){                                   // This function gets a ranging from the SRF08
 int range = 0;
 Wire.write(cmdByte);                             // Send Command Byte
 Wire.write(0x51);                                // Send 0x51 to start a ranging in cm
 delay(80);                                     // Wait for ranging to be complete
 Wire.beginTransmission(srfAddress);             // start communicating with SRFmodule
 Wire.write(rangeByte);                           // Call the register for start of ranging data
 Wire.requestFrom(srfAddress, 2);                // Request 2 bytes from SRF module
 while(Wire.available() < 2);                    // Wait for data to arrive
 byte highByte = Wire.read();                 // Get high byte
  byte lowByte = Wire.read();                  // Get low byte
  range = (highByte << 8) + lowByte;              // Put them together
 return(range);                                  // Returns Range
int getLight() {                                  // Function to get light reading
 Wire.write(lightByte);                           // Call register to get light reading
 Wire.requestFrom(srfAddress, 1);                // Request 1 byte
 while(Wire.available() < 0);                    // While byte available
 int lightRead = Wire.read();                 // Get light reading
 return(lightRead);                              // Returns lightRead
int getSoft(){                                    // Function to get software revision
 Wire.beginTransmission(srfAddress);             // Begin communication with the SRF module
 Wire.write(cmdByte);                             // Sends the command bit, when this bit is read it returns the software revision
 int software = Wire.read();                  // Get byte
   return(software);
Thanks
Why don’t you try something simple first?
As you said nothing is being displayed on your serial monitor try this and see if Serial communications are working fine.
  Serial.println("Hello World");
  delay(1000000000);
Have you run the I2C Scanner sketch, to confirm that you have the correct address for the device?
If you see nothing in the Serial Monitor, it is because you assume that everything is connected correctly, and that you have the proper address. The behavior you see suggests that that is not a valid assumption.
