Bonjour,
Je voudrais adapter le code de l'exemple de la librairie DFRobot_ECPRO sur un ESP32 TTGO LoRa.
Il doit y avoir des ajustements sur la tension d’entrée.....?
Voici le lien vers la fiche technique de la sonde ![]()
Merci d'avance pour votre aide.
* @copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @licence The MIT License (MIT)
* @author PengKaixing(kaixing.peng@dfrobot.com)
* @version V0.1
* @date 2021-05-31
* @get from https://www.dfrobot.com
* @url https://github.com/dfrobot/DFRobot_ECPRO
#include "DFRobot_ECPRO.h"
#define EC_PIN A1
#define TE_PIN A2
#define ADC_DIGIT 1024.0
#define REFERENCE_VOLTAGE 5.0
* 获取的电导率电压值和温度电压值
float EC_voltage,TE_voltage;
float temp,conductivity;
DFRobot_ECPRO ec;
DFRobot_ECPRO_PT1000 ecpt;
* 校准 ETALONNAGE
EC_voltage = analogRead(EC_PIN) / ADC_DIGIT * REFERENCE_VOLTAGE;
ec.setCalibration(ec.calibrate(EC_voltage));
Serial.print("calibration value is :");
Serial.println(ec.getCalibration());
* 获取温度值 VALEUR TEMPERATURE
TE_voltage = analogRead(TE_PIN)/1024.0*5;
temp= ecpt.convVoltagetoTemperature_C(TE_voltage);
* 获取电导率值 VALEUR CONDUCTIVITE
conductivity = ec.getEC_us_cm(EC_voltage,temp);
Serial.print("temperature:");
Serial.print(temp);
Serial.print("^C EC:");
Serial.print(conductivity);
Serial.println("us/cm");
