Hi guys
I ordered a 5v low trigger 30A relay as I need to switch a mains (230v) 15 amp load, when the thing arrived it really does not look like it could handle 15A never mind 30A, in fact the terminals would not take a big enough cable. Do any of you have any experience with these relays. Its branded Songle "SLA-05VDC-SL-0C.
Thanks.
This the datasheet for it,
https://arduino-info.wikispaces.com/file/view/SLA-05VDC-SL-C_Datasheet.pdf/577719703/SLA-05VDC-SL-C_Datasheet.pdf
I use these type of relays in repair of Test and Tag equipment where they switch 25Amps.
The relays I use are of the same form factor and pin gauge, but I prefer to use.
This is a 24Vcoil but the documentation indicates other coil voltage.
Tom...
