Sonnenaufgangszeit rechnen
// accompanies thread in German Arduino forum: http://forum.arduino.cc/index.php?topic=313942.0
// Compare results against: http://www.esrl.noaa.gov/gmd/grad/solcalc/
// Results are reasonable, but not too accurate, so do not use this for scientific purposes!
#include <avr/pgmspace.h> // save RAM with AVR/Atmega controllers in some functions using PROGMEM
#include <Wire.h>  // include Wire library for I2C devices
#include "jursRTCtimeEasy.h" // include RTC time library
#include "sunrise.h" // include library for sunrise/sunset calculations
/*void serialTask()
{ // Check Serial input for time setting command
  char* command=readSerialCommand();
  if (command!=NULL) // we have found a command from Serial
    Serial.print(command);Serial.print('\t');
    if (strncmp_P(command,PSTR("setc "),5)==0 || strncmp_P(command,PSTR("setd "),5)==0) // compare for command
      if (handleRtcCommand(command)) Serial.println(F("OK"));
      else Serial.println(F("ERROR: invalid time not set"));
    else Serial.println(F("Unknown command")); // handle other commands here
enum {DAY, NIGHT, DAWN};
int getDayState(sTime time, int dawn, int sunrise, int sunset, int dusk)
{ // returns DAY, NIGHT or DAWN value, depending on time and sun position
  int minuteAfterMidnight= time.bHour*60+time.bMinute;
  if (minuteAfterMidnight>=sunrise && minuteAfterMidnight<sunset) return DAY;
  else if (minuteAfterMidnight<dawn || minuteAfterMidnight>=dusk) return NIGHT;
  else return DAWN;
#define UPDATEINTERVAL 10000  // milliseconds
#define LAT 46.95  // latitude in degrees, south is negative (used in sun calculation)
#define LON 15.05  // longitude in degrees, west is negative (used in sun calculation)
const char timeFormat[] PROGMEM="%02d.%02d.%04d  %02d:%02d:%02d";
void rtcTask()
  static unsigned long lastUpdate; // remember last time this function has run
  sTime time; // variable to hold current time/timezone
  char buf[61]; // variable for output formatting
  if (millis()-lastUpdate>=UPDATEINTERVAL)
    lastUpdate+=UPDATEINTERVAL;
    RTCreadLocalTime(time); // read localTime (use summertime, if applicable)
    snprintf_P(buf,sizeof(buf),timeFormat,time.bDay,time.bMonth,time.iYear,time.bHour,time.bMinute,time.bSecond);
    if (time.sTimezone==TIMEZONE+1); // strcat(buf," *"); // indicates summertime
    Serial.println(buf);   // show it on serial
    // now do the calculation for dawn/sunrise/sunset/dusk times today
    int sunrise, sunset, dawn, dusk;
    sunCalc(time.iYear,time.bMonth,time.bDay,time.sTimezone, LAT, LON, sunrise, sunset, dawn, dusk);
    snprintf_P(buf, sizeof(buf), PSTR("Dawn: %02d:%02d,  Sunrise: %02d:%02d,  Sunset: %02d:%02d,  Dusk: %02d:%02d"), dawn/60, dawn%60, sunrise/60, sunrise%60, sunset/60, sunset%60, dusk/60, dusk%60);
    // Finally find out whether we have DAY, NIGHT or TWILIGHT time of the day
    switch (getDayState(time, dawn, sunrise, sunset, dusk))
      case DAY: Serial.println("DAY");break;
      case NIGHT: Serial.println("NIGHT");break;
      default:  Serial.println("TWILIGHT");break;
      Serial.println(dawn);
/*void usage()
{ // show some information about program usage
  Serial.println(F("\nRTC date and time library demo by 'jurs' for German Arduino forum\n"));
  Serial.println(F("Usage for setting RTC date/time from Serial monitor in format"));
  Serial.println(F("\nOr you can use German date formatting with the 'setd' command:"));
  Serial.println(F("setd 24.12.2016 9:30:12     (24. Dezember 2016 um 9:30:12 Uhr)"));
  Serial.println(F("Time setting is in local time during summertime!\n\n"));
//  usage();
  if (RTCinit()) Serial.println(F("RTC OK"));
  else Serial.println(F("RTC/I2C ERROR"));
//  serialTask();
  rtcTask();
Hallo, ich hab folgenden Sonnenaufgang Sketch in Verwendung. Nun würde ich gern mit der Sonnenaufgangszeit bzw. Untergangszeit weiterrechnen. Will nämlich für meinen Hühnerstall eine zusätzliche Beleuchtung im Stall einschalten wenn zwischen Sonnenaufgangzeit und Untergangszeit <16h liegen.
Wie kann ich sowas am Besten angehen? DANKE
r_robert:
if(sonnenuntergangszeit-sonnenaufgangszeit < 16)
  beleuchtungeinschalten();
Gruß
Gregor
Die Sonneuntergangszeit bekomme ich aber getrennt (Minuten und Stunden extra) aus dem obrigen Sketch. Brauch ich hier nicht eine zusammengefügte Variable?
Hi
Du bekommst alle vier Werte in 'Minute am Tag' - Die kann man direkt miteinander verrechnen, man muß halt schauen, ob die Differenz 'die in 16 Stunden enthaltenen Minuten' überschreitet.
MfG
Dann wäre der Code so?
if(sunrise-sunset< 960)
Hi
Wenn Du in UNSIGNED rechnest, passt Das immer.
sunrise - Sonnenaufgang
sunset - Sonnenuntergang
dawn - Morgen- Dämmerung
dusk - Abend-Dämmerung
Jeweils als 'Startminute'.
Wenn müsstest Du sunset-sunrise nutzen, oder?
Da der Sonnenuntergang wohl erst nach dem Aufgang kommt, ist Das der größere Wert.
MfG
Hallo
ja stimmt ich muss sunset-sunrise rechnen.
Wie könnte ich mit der Uhrzeit (z.B.: von der sunset) anstatt UNSIGNED wirklich als Uhrzeit ausgeben und damit rechnen? Danke schon wieder einmal vorab :slight_smile:
Hi
Reine Theorie!
So wie ich Das verstehe, gibt die Funktion die Zeitpunkte als 'Minute am Tag' zurück.
Wenn her Sonnenaufgang um 6:00h, ist der Wert wohl 360.
Wenn der Sonnenuntergang nun um 18:00h ist, dieser Wert wohl 1080.
Die Differenz wäre 720, was geteilt durch 60 - Du ahnst Es schon, 12 (Stunden) ergibt.
MfG
Hab das jetzt einmal via serialprint ausgegeben.
So bekomme ich bei der Sunrise nur 5 anstatt 5:13Uhr heraus
27.05.2020 21:50:46
Dawn: 04:42, Sunrise: 05:13, Sunset: 20:41, Dusk: 21:12
sunrise: 313
sunrise/60: 5
Hi
Wie hat denn der Erbauer der Funktion die Minuten_am_Tag wieder in Stunden und Minuten umgewandelt?
Stunden per Division
Minuten per Modulo
Was willst Du nun aber mit den Stunden und Minuten? Damit lässt sich nur schwer rechnen.
MfG
r_robert:
Stimmt. Das macht genau das, was Du willst.
Das was Du suchst, nennt sich Rest einer Division.
unsigned long sunrise=313;
  Serial.println(sunrise%60);
Den Rest bekommst Du hin :wink:
ich habs jetzt so ausgeben probiert
Serial.print("Sunrise: %02d:%02d "),dawn/60, dawn%60;
Kann ich die Stunden (5) und Minuten (13) nicht irgendwie in eine Variable zusammenfassen?
r_robert:
Du hast die doch in einer Variablen.
Das rausrechnen kannst Du jederzeit wiederholen.
Warum muss ich das Serial.println(sunrise%60); im setup ausführen?
r_robert:
Musst Du nicht.
Ich wollte Dir zeigen, Wie Du zu der Ausgabe kommst, die Du benötigst.
Im Loop würde das die ganze Zeit den Ser.Mon zuschieben.
[edit]
OH entschuldige, Du hast nicht mitbekommen, das meine Variable sunrise oben zum Code gehörte. War mein Fehler beim formatieren.
Wenn Du jetzt den vollständigen Code nimmst und bei Dir ausführst, dann bekommst Du die Lösung.
[/edit
Hi
WAS willst Du wirklich?
Entweder hast Du absolut nicht verstanden, welche Informationen Dir die Lib liefert, oder ich Dein Problem nicht.
if (sunset-sunrise>=16*60){
//mache was, wenn zwischen SonneAUFgang und SonnenUNTERgang mindestens 16 Stunden liegen
Die Rückgabewerte sind Zahlen von 0 bis 1439 (ein Tag hat 1440 Minuten).
Somit ist die Differenz dieser Werte ebenfalls in Minuten.
Dann musst Du nur noch diese Differenz mit der von Dir gedachten Zeit (in Minuten) vergleichen.
MfG
in Stunden und Minuten wäre es einfach übersichtlicher, aber ich rechnen nun einfach in Minuten weiter... Ist glaub ich das einfachste.
Danke für eure Hilfe..
[Ps.: Bin leider erst Anfänger beim Programmieren.. :slight_smile: ]
r_robert:
leider? erst?
Nicht doch!
postmaster-ino hat recht, wenn es um die Rechnerei innerhalb deines Codes geht.
Ich habe Dir gezeigt, wie Du an die fehlenden Daten bei der Ausgabe kommst.
Ich gebe mir aus Überzeugung Mühe jedem weiterzuhelfen. Und das tuen hier auch viele andere. Da spielt es keine Rolle, ob "Anfänger" oder "Fortgeschrittener" (Ab wann ist man das?)
r_robert:
in Stunden und Minuten wäre es einfach übersichtlicher, ...
Für Dich schon, weil Du es so gewohnt bist, ein µC sieht das aber ganz anders, denn der kann nur binär. Daher rechnen auch bekannte Tabellenkalkulationen mit Sekunden seit 1900 oder seit 1970 (Unixzeit). Man muß sich klar machen, daß Zeit immer relativ1) ist. Wir geben die Tageszeit relativ zu Mitternacht an, ebenso wie das christliche Datum relativ zur Geburt eines Menschen2). Die Entstehung unseres Universims als absoluten Nullpunkt der Zeit wäre eventuell eine Möglichkeit, aber selbst die PTB in Braunschweig hat da keine passende Uhr.
Der leider in Forum nicht mehr aktive jurs hat allerdings Zeiten auch als ganze Zahlen gespeichert. Beispielsweise 20:15 Uhr als Zahl 2015. Eine Divisuion durch 100 bringt die Stunden, Modulo 100 die Minuten. Das hat durchaus praktischen Nutzen.
Rechnen würde ich, wie schon gesagt, in Minuten, Anzeige dann in hh:mm. Eine kleine Funktion kann helfen:
char zeit[] = {"00:00"};
char * zeitanzeige(uint16_t minuten) {
  byte h = minuten / 60;
  byte m = minuten % 60;
  snprintf(zeit, sizeof(zeit), "%2d:%2d", h, m);
  return zeit;
  Serial.println("Anfang");
  static uint16_t zeitinminuten = (10 * 60) + 44;
  Serial.println(zeitinminuten);
  Serial.println(zeitanzeige(zeitinminuten));
  zeitinminuten++;
  delay(1000UL * 60);
Anm.:
  1. Ganz unabhängig von Überlegungen zur Raumzeit der Relativitätstheorie!
  2. Wobei Jesus tatsächlich wohl nicht im Jahr 0 geboren wurde.
EDIT: "1000" geändert in "100" siehe #19. Danke!
agmue:
Der leider in Forum nicht mehr aktive jurs hat allerdings Zeiten auch als ganze Zahlen gespeichert. Beispielsweise 20:15 Uhr als Zahl 2015. Eine Division durch 1000 bringt die Stunden, Modulo 1000 die Minuten. Das hat durchaus praktischen Nutzen.
Müsste es nicht 100 sein, statt 1000?
