Sonoff S26 button and UDP command not working well
Hello,
I have made an program to control an Sonoff S26 with the button on the unit en to send commands to the unit over UDP.
It is working for 95%
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
const char* ssid = "****";
const char* password = "****";
WiFiUDP Udp;
unsigned int localUdpPort = 7;  // local port to listen on
char incomingPacket[255];  // buffer for incoming packets
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];    //Buffer for received data
// GPIO0 Push Button HIGH = off, LOW = on
// GPIO12  Relay and Red LED
// GPIO13  Blue Status LED
int relayState=0;
int gpio_0_switch = 0;
int gpio_13_led = 13;
int gpio_12_relay = 12;
int buttonNew;
int buttonOld=1;
int dt=100;
  pinMode(gpio_13_led, OUTPUT);
  digitalWrite(gpio_13_led, LOW);
  pinMode(gpio_12_relay, OUTPUT);
  digitalWrite(gpio_12_relay, LOW);
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    digitalWrite(gpio_13_led, HIGH);
  Serial.println(" connected");
  Udp.begin(localUdpPort);
  Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
void loop(){
int packetSize = Udp.parsePacket();
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);    //if data received read it
buttonNew=digitalRead(gpio_0_switch);
  if(strcmp(packetBuffer, "UDP-ON") == 0){
     digitalWrite(gpio_12_relay, HIGH);
     relayState=1;
  if(strcmp(packetBuffer, "UDP-OFF") == 0){
     relayState=0;
  if(buttonOld==0 && buttonNew==1) {
    if (relayState==0) {
      relayState=1;
    else{
      relayState=0;
  buttonOld=buttonNew;
when I powered on I can control the unit with the button that is working,
to send the commands over UDP two times.
What also works is when I push the button to on then I can send the command off that is working
I hope some one can help me with this
thanks in advance!
