Sony Ericsson - RS232 - Rx/Tx serial help :)
Hi there :slight_smile: ,
I would like to use my old SOny Ericsson W810i or K610i to send sms.
I plan to use my arduino to send at commands.
I don't know how to interface those phone.
Here is the pinout :
pin no. 1 = +5 v
pin no. 5 = Tx RS232
pin No. 6 = Rx RS232
pin no. 9 = Gnd
pin No. 10= USB Data +
pin no. 11= USB Data -
It is possible to use directly the Usb d+/d- and use it as a Serial port on arduino? Or I have to find a way to convert RS232 to serial?
Thank you for your help!
AloyseTech
Yes, if the phone is a USB master. Otherwise, no, can't connect two USB slaves.
RS232 to serial, just need a MAX232 or MAX3232 type chip, or a module depending on the connector needs
http://www.nkcelectronics.com/rs232-to-ttl-converter-board-33v232335.html
http://www.nkcelectronics.com/RS232-to-TTL-converter-board-DTE-with-Male-DB9-33V-to-5V_p_369.html
One question, one topic please. Have a little patience for a reply.
CrossRoads:
But if I use a Softwareserial port to communicate between the two, there will be each Master and slave alternatively ?
Serial back & forth with Rx/Tx at up to 4800 is entirely different from USB running at 12 Mybytes/sec & the USB protocol that goes on between master/host & slave.
CrossRoads:
But if I want to send AT commands I have to use the Serial Rx/Tx, no?
Or maybe I could use a USB host shield? I'm not really good at communication stuff... :confused:
"if I want to send AT commands I have to use the Serial Rx/Tx"
I believe that is correct.
And What about the USB host Shield? Do you think it is possible to communicate this way?
