Hi I'm new to the arduino ( got it yesterday
) and after blinking a LED and playing with some CdS cells and a servo I got the arduino reading a sony remote. The code worked great, it was giving me the codes when i pressed buttons on my remote.
Now I wanted to try and learn how to make my own libraries so I thought I would turn this one into a library using the tutorial on the arduino website, problem is I'm stuck. Any help would be appreciated as I really want to know what I'm doing wrong.
First working code:
Program that reads key presses of a sony remote control
Created by Kurtis Waterston, March 6 2010
Realesed into the public domain
*/int irDet = 2;
int key = 0;
int data[12];
int state;void setup() {
Serial.begin(9600); //For debugging
pinMode(irDet, INPUT); //IR detector connected to digital pin 2
}void loop() { //Main loop
if (pulseIn(irDet, LOW) > 2200) { //Check for start pulse
getIRkey();
Serial.print("Key press is = ");
Serial.println(key);
int getIRkey() { //Read pulses
data[0] = pulseIn(irDet, LOW);
data[1] = pulseIn(irDet, LOW);
data[2] = pulseIn(irDet, LOW);
data[3] = pulseIn(irDet, LOW);
data[4] = pulseIn(irDet, LOW);
data[5] = pulseIn(irDet, LOW);
data[6] = pulseIn(irDet, LOW);
data[7] = pulseIn(irDet, LOW);
data[8] = pulseIn(irDet, LOW);
data[9] = pulseIn(irDet, LOW);
data[10] = pulseIn(irDet, LOW);
data[11] = pulseIn(irDet, LOW);for(int x = 0; x <= 11; x++) { //Decide wether pulses are 1's or 0's
if(data[x] > 1000) {
data[x] = 1;
else {
data[x] = 0;
}int result = 0; //Convert array into interger
int seed = 1;
for(int i=0;i<11;i++) {
if(data == 1) {
- result += seed;*
_ seed = seed * 2;_- }*
- key = result;*
- return result;*
[/quote]
Header file:
> IrRemote.h - A library for Sony tv remote control
> Realeased into the public domain
> #ifndef IrRemote_h
> #define IrRemote_h
> #include "WProgram.h"
> class IrRemote
> public:
> IrRemote(int pin);
> int IrReady();
> int IrKey();
> private:
> int _pin;
> int _data[12];
> int _seed;
> int _result;
> #endif
CPP file:
> IrRemote.cpp - A library for sony tv remote control
> Released into the public domain
> #include "IrRemote.h"
> IrRemote::IrRemote(int pin)
> pinMode(pin, INPUT);
> _pin = pin;
> int IrRemote::IrReady()
> if(pulseIn(_pin, LOW) > 2200) {
> return 1;
> else {
> return 0;
> int IrRemote::IrKey()
> _data[0] = pulseIn(_pin, LOW);
> _data[1] = pulseIn(_pin, LOW);
> _data[2] = pulseIn(_pin, LOW);
> _data[3] = pulseIn(_pin, LOW);
> _data[4] = pulseIn(_pin, LOW);
> _data[5] = pulseIn(_pin, LOW);
> _data[6] = pulseIn(_pin, LOW);
> _data[7] = pulseIn(_pin, LOW);
> _data[8] = pulseIn(_pin, LOW);
> _data[9] = pulseIn(_pin, LOW);
> _data[10] = pulseIn(_pin, LOW);
> _data[11] = pulseIn(_pin, LOW);
> if(_data[x] > 1000) {
> _data[x] = 1;
> else {
> _data[x] = 0;
> _result = 0;
> _seed = 1;
> if(_data == 1) {
> * _result += _seed;
_> * }_
> _seed = _seed * 2;
> * return _result;*
> [/quote]
> New Code using created library:
> > #include <IrRemote.h>
> > int key;
> > int State = 0;
> > IrRemote IrDet(2);
> > void setup() {
> > Serial.begin(9600);
> > void loop() {
> > State = IrRemote.IrReady();
> > key = IrRemote.IrKey();
> > Serial.print("Remote Key = ");
> The problem is when I try and verify the new code I get this error:
> > In function 'void loop()':
> > error: expected primary-expression before '.' token
> Again any help would be appreciated as I really want to learn how to work with this awesome tool and create more libraries. Thanks in advance.
