I'm having trouble sorting through language differences in getting back into this. It had been a while and i have syntax from C++, Java, and python making a lot of noise over top of the compiler syntax here.
I'm trying to make an order randomizer, in this case, I'm just trying to see the final array in some way. I think I've botched at least the output, and oh by the way I'm exhausted from getting this far weeding through the cross-language pseudocode in my head.
suggestions greatly appreciated
-cb
int len = 32;
int outArray[32];
void setup(){
void loop(){
uint8_t a;
populator(outArray);
for( a = 0; a <len; a++)
Serial.print(outArray[a]);
void populator(int outIndexes[] )
//build scrambled index array where each index is used only once
bool indexCheck[len];
uint8_t i;
int ix;
for( i=0; i<len; i++)
indexCheck[i]=true;
//fill array with marker data
outIndexes[i]=len+1;
//iterate through output array, assigning index by rand%numPixels
while(outIndexes[i]=len+1)
ix=random(len);
if(indexCheck[ix]){
outIndexes[i]=ix;
indexCheck[ix]=false;}
Thanks AWOL, last night I sat bolt upright in bed realizing a better way to do the sorting, and how slow this one was.
But, I also was trying to figure out a timing issue, and I thought about using the two flaws together interestingly.
Using a LPD8806, I had the sorting array update the strip as it found a new index location. As the newness of the array fills up, it takes a good while longer to generate enough numbers to hit a new one - a tried and true lame programming move.
But a good delay pattern for cycling through updating the colors to let them hang on for a little while without an actual delay() call. (just plenty of wasted calls to random())
#include <avr/pgmspace.h>
#include "SPI.h"
#include "LPD8806.h"
const int len = 32; //number of pixels
int outArray[len]; //also used here
int dataPin = 16;
int clockPin = 15;
LPD8806 strip = LPD8806(len, dataPin, clockPin);
void populator(int outIndexes[] );
void setup(){
strip.begin();
randomSeed(analogRead(0));
strip.show();
void loop(){
//uint8_t a, r, g, b;
Serial.println('a');
/*for( a = 0; a <len; a++)//debug printing the array
Serial.print(',');
Serial.println();*/
uint8_t i, r, g, b;
int ix;
Serial.println('b');
indexCheck[i]=true;
//clear array with invalid data
Serial.println('c');
Serial.println('d');
while(outIndexes[i]==len+1)
Serial.println('e');
ix=random(len);
if(indexCheck[ix])
outIndexes[i]=ix;
r=random(127);
g=random(127);
b=random(127);
strip.setPixelColor(ix, r, g, b);
strip.show();
// -- see: http://en.wikipedia.org/wiki/Fisher-Yates_shuffle
void shuffle (int * t, int n)
while (--n >= 2)
// n is now the last pertinent index
int k = random (n); // 0 <= k <= n - 1
// Swap
int temp = t [n];
t [n] = t [k];
t [k] = temp;
} // end of while
} // end of shuffle
const int NUM = 30; // how many
void setup ()
int t [NUM];
// populate table
for (int i = 0; i < NUM; i++)
t [i] = i;
// shuffle it
shuffle (t, NUM);
// print table
Serial.begin (115200);
Serial.println (t [i]);
} // end of setup
void loop () {}
