I have been working on a project which consists of two Uno’s and a Mega. The Uno’s each have an MPU-9150 attached and I am sending the values over an xbee to the Mega.
I am sending in the format of <SensorID,time,aX,aY,aZ,gX,gY,Gz.> at 100Hz.
I am able to collect the data from both Uno’s successfully in a .bin file, however I was wondering if there was a way to sort the two incoming messages in to columns within the bin file?
This is the example code I am using to store the values at the moment and it works pretty well, but it stores them in a column as they are received. If possible I would like to have Column 1 - Sensor 1, Column 2 - Sensor 2.
// Serial data logger example.
// Maximum baud rate for a Mega Arduino is 115200.
const uint32_t BAUD_RATE = 57600;
// Maximum time between sync() calls in milliseconds. If Serial is always
// active, you must provide a way to stop the program and close the file.
const uint32_t MAX_SYNC_TIME_MSEC = 1000;
// Pin number for error blink LED.
// Set ERROR_LED_PIN to -1 for no error LED.
const int8_t ERROR_LED_PIN = 3;
#include <SdFat.h>
#include <SerialPort.h>
#if defined(__AVR_ATmega1280__)\
|| defined(__AVR_ATmega2560__)
// Mega, use 4096 byte RX buffer
SerialPort<0, 4096, 0> NewSerial;
#else // Mega
// not a Mega, use 1024 RX byte buffer
SerialPort<0, 1024, 0> NewSerial;
#endif
SdFat sd;
SdFile file;
// Error codes repeat as errno short blinks with a delay between codes.
const uint8_t ERROR_INIT = 1; // SD init error
const uint8_t ERROR_OPEN = 2; // file open error
const uint8_t ERROR_SERIAL = 3; // serial error
const uint8_t ERROR_WRITE = 4; // SD write or sync error
void errorBlink(uint8_t errno) {
uint8_t i;
while (ERROR_LED_PIN < 0);
while (1) {
for (i = 0; i < errno; i++) {
digitalWrite(ERROR_LED_PIN, HIGH);
delay(200);
digitalWrite(ERROR_LED_PIN, LOW);
delay(200);
delay(1600);
pinMode(ERROR_LED_PIN, OUTPUT);
NewSerial.begin(BAUD_RATE);
if (!sd.begin()) {
errorBlink(ERROR_INIT);
if (!file.open("SERIAL.BIN", O_WRITE | O_CREAT | O_AT_END)) {
errorBlink(ERROR_OPEN);
if (file.fileSize() == 0) {
// Make sure first cluster is allocated.
file.write((uint8_t)0);
file.rewind();
file.sync();
// Time of last sync call.
uint32_t syncTime = 0;
uint8_t buf[32];
if (NewSerial.getRxError()) {
errorBlink(ERROR_SERIAL);
uint8_t n = NewSerial.read(buf, sizeof(buf));
if (n > 0) {
if (file.write(buf, n) != n) {
errorBlink(ERROR_WRITE);
// Don't sync if active.
return;
if ((millis() - syncTime) < MAX_SYNC_TIME_MSEC) return;
if (!file.sync()) {
syncTime = millis();
Apologies if this is something easy I have missed in the examples given but I have hit a road block (impressed I managed to get this far to be honest).
