SOS using AnalogWrite
I'm not sure if this is where this should be posted or not. So forgive me if I'm wrong. I am trying to make a RGB LED strip blink SOS in Morse code. I've successfully made a single LED using DigitalWrite blink, however I am having a difficult time using AnalogWrite. The LED's work just not blinking SOS. Below is the code I am using:
//LED Red=256, Green=127, Blue=0
int Pin_LED_Red=3;
int Pin_LED_Green=5;
int Pin_LED_Blue=6;
  // set mode of pins as outputs to run once
  pinMode(Pin_LED_Red,OUTPUT);
  pinMode(Pin_LED_Green,OUTPUT);
  pinMode(Pin_LED_Blue,OUTPUT);
  // 3 Dits
  for(int x=0;x<3;x++)
  analogWrite(Pin_LED_Red,250); // Mav intensity of red;
  analogWrite(Pin_LED_Green,125); // Half intensity of Green;
  analogWrite(Pin_LED_Blue,0); //No Blue because Red and Green make Orange
  delay(100); //DelaayON tine 100 ms
  // Off for 200 ms
  analogWrite(Pin_LED_Red,0);
  analogWrite(Pin_LED_Green,0);
  delay(200);
 // 3 Dahs
  delay(300); //DelaayON tine 300 ms
 // Off for 200 ms
  delay(300);
   // 3 Dits
  analogWrite(Pin_LED_Red,259); // Mav intensity of red;
Thanks for any and all help
moderator: added code tags ==> # button above the smileys
Check your { and }
where?
Wherever they appear; how else are you going to check them?
I'm sorry I misinterpreted your suggestion, I was looking for an AND statement
And check where you don't have them, but where you should.
I though that if I hovered near one curly bracket, it would show its mate. It doesn't seem to do that
There aren't any (that was a clue) in the fragment I quoted.
Jasiu:
maybe you're not looking far enough away.
Jasiu:
Not hover; the cursor needs to be after the bracket you're seeking a mate for.
Or use auto format (tools menu) to show you the structure of your code. Auto formatting before posting saves every one time!
Mark
Speaking of saving time, why are you using analogWrite() to blink an LED?
I don't think he is. He's using to get different colours.
Mark
You can simplify the code a bit by using functions. Also, note that some of your comments don't square up with your code. Misleading comments are worse than no comments. Your last call to the RED led passed in a value of 259...probably not what you want. Also, Morse has a pretty well-defined relationship for spacing, but here I've just used the dot-to-dash ratio. Finally, delay() is not a good choice for program delays. (See the Blink Without Delay example provided with the IDE.)
#define DIT 100
#define DAH (DIT * 3)
int Pin_LED_Red=3;
int Pin_LED_Blue=6;
  int x;
  for(x = 0; x < 3; x++)    // Three dits
    sendChar(DIT);
    pause(DIT);
  delay(DIT + DAH);         // Inter-character spacing for Morse
  for(x = 0; x < 3; x++) {  // Three dahs
    sendChar(DAH);
    pause(DIT);
  delay(DIT + DAH);
    sendChar(DIT);
    pause(DIT);
  delay(DAH * 5);              // Rest between messages.
void pause(long ms)
  delay(ms);
void sendChar(long ms)
  delay(ms);
Thank you so much! That is a much better way of doing it :slight_smile:
