Bonjour,
J'aimerais faire un petit jeu à mon enfant pour qu'il voit les possibilités avec l'électronique mais moi je ne connais absolument pas grand-chose...
J'aimerais pouvoir afficher une image sur Processing lorsqu'on clap des mains.
Pour cela j'ai un sound detector sparfun - arduino uno.
J'utilise ce code sur arduino :
// Define hardware connections
#define PIN_GATE_IN 2
#define IRQ_GATE_IN 0
#define PIN_LED_OUT 13
#define PIN_ANALOG_IN A0
// soundISR()
// This function is installed as an interrupt service routine for the pin
// change interrupt. When digital input 2 changes state, this routine
// is called.
// It queries the state of that pin, and sets the onboard LED to reflect that
// pin's state.
void soundISR()
int pin_val;
pin_val = digitalRead(PIN_GATE_IN);
digitalWrite(PIN_LED_OUT, pin_val);
// Configure LED pin as output
pinMode(PIN_LED_OUT, OUTPUT);
// configure input to interrupt
pinMode(PIN_GATE_IN, INPUT);
attachInterrupt(IRQ_GATE_IN, soundISR, CHANGE);
// Display status
Serial.println("Initialized");
int value;
// Check the envelope input
value = analogRead(PIN_ANALOG_IN);
// Convert envelope value into a message
Serial.print("Status: ");
if(value <= 10)
Serial.println("Quiet.");
else if( (value > 10) && ( value <= 30) )
Serial.println("Moderate.");
else if(value > 30)
Serial.println("Loud.");
// pause for 1 second
et celui-ci sur processing :
import processing.serial.*;
Serial myPort; // Create object from Serial class
static String val; // Data received from the serial port
int sensorVal =0;
//import processing.video.*;
//Movie myMovie;
PImage singe;
size(1920, 1080);
// myMovie = new Movie(this, "gradient.mov");
//myMovie.play();
singe = loadImage("singe.png");
String portName = Serial.list()[2]; //change the 0 to a 1 or 2 etc. to match your port
myPort = new Serial(this, portName, 9600);
void draw() {
//image(myMovie, 0, 0);
singe.resize(0, 250);
image(singe, 550 , 350);
if ( myPort.available() > 0)
{ // If data is available,
val = myPort.readStringUntil('\n');
println(val); //print it out in the console
//void movieEvent(Movie m) {
// m.read();
mais je n'ai vraiment aucune idée sur comment dire à processing d'afficher l'image quand il y a eu un son detecté, et je ne trouve pas grand-chose sur github ou autre. Avez-vous des idées sur comment je peux faire ?
je vous remercie énormément d'avance pour votre aide
bonne journée
