Sound & Knock sensor problem
Hello all,
I just got two new sensors: a sound sensor and a knock sensor. In the attachment I've uploaded some photos of the setup (sorry for the quality). The problem I have is that the two sensors are only returning the value 1023 and don't react on differences in the input.
This is the code I use (just to check if everything is working allright):
const int knockPin = A1;
const int soundPin = A0;
int knockVal = 0;
int soundVal = 0;
void setup () {
void loop (){
knockVal = analogRead(knockPin);
Serial.print ("Knock Value: ");
Serial.print (knockVal);
soundVal = analogRead(soundPin);
Serial.print (",Sound Value: ");
Serial.println (soundVal);
delay(10);
These are the sensors (the language is dutch btw)
The knock_sensor seems to be digital.
Try connecting it to an interrupt pin.
That sound detector.. Hmmm. Also best suited to trig at a set level -> digital input
Does it help if you select the input mode on the setup?
pinMode(knockPin ,INPUT);
pinMode(soundPin ,INPUT);
Thanks for the replies guys!
@knut what do you mean with and interrupt pin, is that PWM?
I've tried to connect to digital PWM pin but then I only get '1' from both sensor, but I assume this is because a digital pin can only have two values right?
I've also tried to add the pinMode statement, but that doesn't make a difference.
Have you checked out the examples of the knock sensor in the arduino ide?
kevintutor74:
http://www.arduino.cc/en/Tutorial/Knock
Yes I did but that example is with a piezo. I've tried using a 1 meg-ohm resistor between the knock sensor and ground, but that doesn't make a difference.
It's quite frustrating. Does anyone can tell me what I'm completely missing here?
