Sound low on big piezzo with TIP122
I start with the electronics. I would like to control a buzzer with a mosfet P30N06LE on an arduino. The sound is really very low. How to get a powerful sound.
Thank for reply :slight_smile:
Easy, just buy a more powerful piezo .
Try adding a "pull-up" resistor in parallel with the piezo (maybe ~1K).
BTW - Your schematic shows a transistor, not a MOSFET, so hopefully it's wired correctly.
The frequency matters. Piezos are not good at low frequencies. They tend to be most-efficient around 2kHz, which coincidentally is around the maximum sensitivity of human hearing.
A [u]Piezo Horn Tweeter[/u] would (probably) be louder.
Higher voltage will make it louder. Double the voltage is +6dB louder (4 times the wattage). An H-driver will double the (peak-to-peak) voltage with the same power supply.
Piezo elements are capacitors and require push-pull drive, not single ended, as they do not conduct DC.
